I agree that peak rate isn't what matters, but if you know where the peak rate is sustained and where it is expected to ramp up and down, you can plan to arrive at the supercharger with an optimal SOC to take advantage of it. It used to be the case that the peak rate was reached relatively quickly, and only ramped down as you filled up (remember the "filling a glass of water so you don't spill over" analogy?) Now we have different behavior being reported, and I think it's important to know whether an adjustment in our behavior is needed to minimize the time spent at each supercharger.
Also close but not quite...Close but not quite. Not just prototypes, when I bought my Model S in 2013 it had the two settings, daily (93%) and trip (100%). The slider was introduced with a firmware update I think in 2014. It's because EPA would determine range by averaging the two settings (that's what they did in the early Leaf). By having a slider rather than two settings the EPA uses the range at 100% charge.
not with throtteling .xDA quote from Tesla's Enable Supercharging page, which may or may not be relevant today:
Exactly. The point is that the superchargers are being advertised as "designed to replenish over half a charge in 20 minutes." That's a big selling point, because needing to spend 20 minutes at a supercharger stop sounds a lot better to a prospective owner than needing to spend an hour.not with throtteling .xD
If I arrive at a low SOC and get throttled down to 50 kW right away, as in @David99 's graph, then by definition it's going to take longer to get the energy I need to continue my trip, compared to when the supercharger could sustain a rate of ~100kW between 10% and 50%. Certainly it's going to be more than 20 minutes. Also, it's extra time that stall is unavailable for the next person to use.
Careful not to conflate these two instances of throttling. One appears to be driven by overheat protection of the connector handle, while the other is clearly related to degradation of the cells in the pack.
Would tesla replace a battery just because of slow charging? From everything I've read it seems that Tesla fights hard not to give people new batteries under most circumstances. Maybe someone has a better idea than me. Tesla flat out refused to give me an answer 5 different times about how its battery warranty actually works, and they also refused to tell me on many occasions what a normal battery degredation rate is. The best I could get out of them was that they monitor battery logs and if they see anything abnormal they'll be proactive an contact the customer to let them know something is wrong. So, they have all the power, and with no information out there on what is abnormal, when you go to tell them you have 10% degredation and need a new battery, they can easily say "that's normal."
- Just thinking of downside risk, what about the battery swapping program of the past. Tesla apparently knows how to rapidly replace the whole pack if they have a warranty problem with the batteries themselves.
I had to resort to reading about owners doing self documentation to actually figure out what a normal battery looks like. Luckily tesla drivers have been pretty meticulous.
It's actually very clear what the battery warranty covers...It covers defects and failures for 8 years. It does not cover normal degradation.That's very true. Tesla has never clearly defined what the battery warranty covers. So far reduction of capacity or performance has not been grounds to replace a battery. We all know batteries age with time and use. Tesla doesn't give us a warranty that this doesn't happen, and i think that is reasonable. But without having defined what normal wear and tear is, what is the threshold? Tesloop had a car with 6% degradation after 200k miles and Tesla replaced the battery with one that also showed 6% loss.
They replaced it because the BMS wasn't properly reporting the charge state, since the BMS code wasn't setup to handle the high mileage of the Tesloop car yet. (At least that is what they said.)
Battery loss will be different if they make tweaks to the chemistry. So far they've always been one of the best in the industry.Since it is undefined what amount of energy or power loss is normal or not, Tesla can define any loss as not covered.
