From my observation it appears Tesla’s plan all along was for us to use home/destination chargers as primary.
If you're willing to supercharge, there's no reason to avoid Chademo stations (the only other type of DC fast charging a Tesla can use) - if anything, the lower peak charge rate of Chademo stations is less potentially damaging to the battery.If I can protect this I’ll continue home charging and occasional Tesla SC and destination chargers, avoiding other brands of DC fast chargers.
Anyone know if this sort of statement is in the latest versions of owners manuals for Model S and X? Newer cars, that is, especially ones with larger batteries?From the Model 3 user manual ... the saga continues
The original 70 battery pack was also correctly advertised with a reported 71.2 kWh capacity.
I am still seeing a 114 kW supercharging rate with approximately 30K miles on the clock...
<snip> Can anyone summarize what we know about the degree of restriction on supercharging that is being done? Or what the conditions are that result in such restrictions (how many supercharging cycles, etc.)? <snip>
How would you characterize the amount of high speed DC-DC charging cycles you have used? Did you use Superchargers only for long trips away from home? Or did you use them more routinely? I understand the issue is that cars with some (unknown?) number of high speed charging cycles get limited. Just trying to relate your experience to my 70D, which now has similar mileage to yours. I used Superchargers rather routinely in my first year, out of practical necessity until i could charge at home.
Until we get 200Kwh packs or higher, I am going to assume throttling will happen to all tesla even the current mighty 100D. You really need to charge at less than 1C to reduce throttling issue IMO. At 200KWh you are around 0.6C when using 120KW charger so it will probably eliminate throttling. But by then I am sure tesla will have 350KW supercharger which means we really need 600KWh battery pack to eliminate supercharging throttling.
I think all in all this will be the fact going forward if you fast charge often, you will see reduced supercharging. No real way around it.
If tesla offered battery replacement then maybe it might alleviate the problem a bit by allowing the full speed charging but battery life reduced. But if you can replace your battery pack at a reasonable price then you get your full capacity back when you deemed the cost is right and the range penalty of the old one is too much.
speculate away, but many of the CHAdeMO around here are only 25kW & below. that's not much faster than a 240V dual charger model s.hardly a source of heat.85 Packs don't seem to suffer from throttling so far, so I wouldn't worry about it, either.
There has been some speculation that CHADeMo might be worse for the battery because it is at higher temperatures longer due to charge rate. Whereas the SC will be done charging sooner than the CHADeMo, but the active cooling might negate much of the issue... it's anyones guess at this point and I'd wager on CHADeMo and SC being pretty darn similar as far as battery degradation goes.
Is that what made them degrade so quickly?I don’t think you can make that generalization as it depends on the battery cells. The Nissan Leaf, for example, charges closer to 2C and there haven’t been any reports of throttling AFAIK.
I think one or two studies indicate that QC’ing the Leaf frequently is only causing the batteries to degrade slightly faster versus batteries that are only charged at ~6 KW. It’s more about the overall cell design and the long term exposure to high overall ambient temperatures.Is that what made them degrade so quickly?
Nissan Leaf 30-kwh battery decline 3 times that of earlier electric cars: study
Chademo use has caused throttling issues and is well below 1C. Charge rate is also chemistry dependent so general statements may not be accurate.Until we get 200Kwh packs or higher, I am going to assume throttling will happen to all tesla even the current mighty 100D. You really need to charge at less than 1C to reduce throttling issue IMO.
