4 seconds is acceptable, but I'd prefer 3.
Exactly. I wouldn't mind sub 3's either. 2.x... I can't wait. lol
I dunno. I'd say most people just plug it in over night and not need to worry about it. Faster charging would be most desirable for long distance trips which don't occur all that often. This is despite some people's claims that the extra relaxation the SC stops afford makes the long distance trips that much more pleasant. lol!What about an option for faster charging? For many people, that's probably more important than more range or acceleration.
To get top acceleration you need more than just the big battery. You need big motors, AWD...
Depends on the type of driving you do... if you accelerate once to get on a freeway or you accelerate many times in city traffic..AWD on the new P60D increases the range. If you select just the AWD option the range increases from 201 to 218. It appears to be because it uses two smaller motors instead of one larger motor. And acceleration increases from 5.5 seconds to 5.2 seconds.
If Tesla reduced the AWD acceleration to 8 seconds using smaller AWD motors, what would the increased in range be, if any?
The AWD P60D getting greater range and faster acceleration with smaller motors had nothing to do with type of driving and was based on the baseline parameters uses to determine range and acceleration.
I think the thread is more about building the car to affect the baselines of acceleration and range vs. how to drive to increase range, the topic of another thread perhaps.
The type of driving has everything to do with the range you get from the same equipment.
I wish I could frame this response. This is perfect.The type of driving has everything to do with the range you get from the same equipment. My point is you can have both range and acceleration and limit via software when you want range and unlock it when you want more acceleration and decreased range.
In my opinion, it's better to have it and not use it vs not have it at all.
As to the 60D getting better range and faster acceleration you first have to take into account the configuration for the dual motor setup has more horsepower. Under ideal road conditions, RWD vs AWD will accelerate the same with the same hp. Then range difference is 8 miles due to better efficiency of the dual motor setup.
60D vs 60D on valet mode and you'll probably get more range due to less power draw during acceleration.
Basically, I'll take the best performing model and adjust the range myself as needed.
I don't get it.
With Jack, you have no choice but to spend hours.
Robin
I don't get it. The OP is presumably aware that range vs power is still controlled by driver demand, just like in an ICE vehicle, but is suggesting that battery tech somehow creates a significant tradeoff between the two.
Why do you think the choice is between one or the other? Aren't they orthogonal? One is in chemistry the other is in thermal mgmt?
The EV model is just too efficient at low speeds with all that torque. Tesla just won't leave that on the table. So I expect stronger acceleration than I need and I have to remind Tesla that I want range and reliability and am willing to give up some acceleration.
