Maybe it will never happen, but if it does.. Where should I store my 12v lithium ion jump starter battery pack? My initial thought was the frunk, but if the 12v dies I can't open the frunk. Can I open a door or trunk?
I am fairly certain the M3 only has one method to gain access to the frunk if the 12V dies, and know for certain the M3 only has one "model year" so far.You can access your frunk. There are 2 different methods and it depends on the year of your car. Search YouTube for answers on this.
My plan:It doesn't appear to me that there is any external place to store a 12 volt power supply. When the Model 3 12 volt system is dead, the frunk can be opened by applying 12 volts to the connection behind the tow eye cover on the front bumper. Once the frunk is open, you can access the 12 volt battery connection.
My plan:
1) If I can find a place externally to hide a 12V jumper pack, hide and move 12V emergency frunk leads to 12V jumper pack location
2) If I cannot do the above, place 12V pack internally with 12V emergency frunk leads routed to this internal location, and have a hidden remote activation switch for the 12V jumper pack
Paranoid. Maybe. Stolen motorcycle, stolen car battery, and multiple home break in victim .
My plan:
Exactly. Along with another 12V battery that can be stolen, tow hook, etc....and even then it only gives access to the frunk.
Exactly what I was thinking, there has to be little nook somewhere to hide it externally....found a small (4.5"x2.5"x1") 12 volt lithium ion battery that should operate the frunk latch in an emergency.
From what I have seen, the battery is a standard SLA. I haven't popped off the battery cover on one, so don't know for sure (hint current owner please have a look for us ).If you gotta tow the car anyway...why not just have the tow company bring the external 12V....Guess the bottomline is change out the 12V before it dies...
Just like any other vehicle, if the 12V is totally dead the car will not start.
No one sees the irony here? My mini jump starter (which could be used to open the frunk) is in the frunk. So, if I have 12V to open the frunk, I don't need it! The battery jumper can be used to 1) open the frunk and 2)start the vehicle (which really means pull the high voltage battery in), but where should I store it so that I can use it when the 12v battery dies? No physical key makes this a mystery....
Check the first responders handbook. There is a way to get into the funk without electric.No one sees the irony here? My mini jump starter (which could be used to open the frunk) is in the frunk. So, if I have 12V to open the frunk, I don't need it! The battery jumper can be used to 1) open the frunk and 2)start the vehicle (which really means pull the high voltage battery in), but where should I store it so that I can use it when the 12v battery dies? No physical key makes this a mystery....
