Making the small adjustment to the dock to get the connector to stick out a little further is relatively simple - and only involves a few screws and shaving a very small amount of plastic off one post inside the console. The console is designed so that the plastic piece holding the USB docking connector is removable - worst case, if it gets messed up, it should be possible to get a replacement from Tesla...
Thanks again.
And if the connector does happen to be long enough, and the only modification I need is to rotate the connector 180 degrees, is it possible to rotate it without taking it apart at all (meaning it is built to be able to rotate) or will I still need to take it apart to rotate it and then just put it back together?
Thanks!
