mmccord
No need to disable trip planner. Put in your destination, let the navigation do it's thing. If it adds charging stops, you can tap on trip and then tap on 'Remove all charging stops' and then tap resume. I found the trip planner to be very annoying. It will randomly reroute to chargers, or even tell you to go back to a Supercharger. It's not working that well. By manually removing all charging stops from the trip, you are good to go. Now look at the energy app and use the trip tab.
I have done done a 200 mile trip in 4 degree cold and windy weather. I had to go slow (60-65) but I made it easily. The energy graph prediction works really well and you can adjust your speed to adjust your energy consumption and this way always be on the safe side. The cabin heater also uses some power of course. Just keep it at a low temp setting and you'll be fine.
Uh, why not just disable it and save yourself the effort?
