I'm fairly certain I don't have lowered front suspension on my P3D
Discussion in 'Model 3: Driving Dynamics' started by Love2Run, Jan 6, 2020.
Does it look like the white P3D sits lower?
  1. Yes
    31 vote(s)
    86.1%
  2. No
    5 vote(s)
    13.9%
  1. Love2Run
    Love2Run Member
    Oregon
    So, I've always thought my mid 2018 showroom Red P3D sat a little higher on the front than other P3Ds I've seen. I had the opportunity to sit next to another stock P3D from 2018 and it's pretty clear that their's is about 1/2" lower than mine. I'm about 3 finger on the wheel gap and they are about 2 fingers.
    Nothing heavy in either of the cars. No one in either car.
    What do you think?
  2. BulldogsRus
    BulldogsRus Member
    Boston
    The black rims are nicer. :D
    • Like x 4
    • Disagree x 1
  3. jmaddr
    jmaddr Member
    Florida
    Can you get a part number from you shock and spring?
  4. Love2Run
    Love2Run Member
    Oregon
    I will pop the front wheel off tonight and see if I can find the part numbers.
  5. tomas
    tomas Out of warranty...
    Chicago/Montecito
    White def lower
  6. lottadot
    lottadot Member
    Frisco, TX
    Can you do the photo on a flat concrete slab? Seems like that could simply be the difference from a non-level-gravel lot.
  7. al503
    al503 Member
    Portland
    You might also consider comparing the same side of each car. On some cars, the left or right side is higher that the other. And as someone mentioned above, compare on a flat, hard surface.
  8. tomas
    Chicago/Montecito
    It’s easy. Get tire pressure equal. Park on a hard surface. Measure distance between roadway and bottom edge of car at same point on each car. Then you’ll know.
  9. tpatana
    tpatana Member
    Redmond WA
    Do you know that white is stock?
  10. Love2Run
    Love2Run Member
    Oregon
    Yes, I work with the person who owns the white car. I know they haven't done anything except PPF/Cermic/Tint.
  11. 299792458
    299792458 Member
    Colorado
    definitely make sure both cars are square on equally flat surface. Are your wheels matte black powder coated?
  12. Love2Run
    Love2Run Member
    Oregon
    They are satin black, but I sometimes think they look matte black. I like them when they are clean, otherwise, I wish I had a different color.
  13. JBT66
    JBT66 Member
    Arizona
    Your whole setup looks larger in that pic so it’s really hard to tell.
  14. Love2Run
    Love2Run Member
    Oregon
    In my flat garage, I'm just shy of 5 inches for the following measurement on both sides.
  15. Teedub21
    Teedub21 Member
    Vancouver Washington
    pretty flush for stock. You guys running spacers?
  16. Love2Run
    Love2Run Member
    Oregon
    i haven’t done anything to the car since buying it... except powder coat wheels.
  17. DrSmile
    DrSmile Member
    Northern NJ
    I have a P3D+ and a P3D-. Looking at them side by side they look identical in terms of height, but with the stock 20 inch rims/tires on the P3D+ and the stock 19 inch rims/tires on the P3D-, the P3D+ sits just over half an inch lower measured at the door sills. Right now I have 18 inch Winter tires on the P3D+ and it sits at exactly the same height as the P3D- give or take 1/4 inch. I measured from the edge of the rim on both and I got 6 inches for the P3D+ and 5.5 inches for the P3D-, so those numbers match yours for both cars, meaning they have the same wheel gap.
  18. turns2stone
    turns2stone Member
    Dallas
    My MY2020 Performance measure the same as yours, 5” and 3 fingers.
  19. ianc
    ianc Member
    MY2020 P+ with 20" wheels, and your 5" dimension is 4 & 11\16" on mine,
    Ian
  20. Love2Run
    Love2Run Member
    Oregon
    How about this measurement?
    28.75” on front and 28.5” on the rear. I have 13k miles on the tires, so it would have been slightly taller with fresh tires
