When sitting on our back porch within 10 feet of our M3 we hear clicking and some clunk sounds from the car. Can being that near the car keep it "alive" and cause the drain problems we are seeing?
It has been awhile since I messed with the Sentry functionality in the Stats app, but IIRC, Stats has (or at least had) the ability to enable sentry mode if you forgot to do it. So even if you told the car to turn Sentry mode off, Stats would turn it back on. Stats would send your phone a message to let you know that it had enabled Sentry mode. Might be a good idea to check out Stats and make sure you don't have it set to auto enable Sentry mode.On my Stats App the drain rate says it is better than 15% of users. Can it be the sentry? I don't turn it on when we go to the boat but I get "sentry enabled" messages. IO thought it stayed off unless enabled??
If you have FSD then turn off Summon or Smart Simmons, as far as Data Sharing, you need to uncheck those boxes. When the boxes are checked this allows the car to upload driving info to Tesla. Also turn off or disconnect any 3rd party App like Teslafi, ABRP, Stat etc. don’t wake the car by opening the Phone App.I didn't want to start a new thread so I shall revive this one. My phantom drain isn't horrible, but I've read stories on here about losing only a few % over the course of a week or two. I've lost 2% since Saturday night.
I have sentry mode on, but, it's set to be off at home. In my app it shows as off when I'm home. Does it still drain the battery? I've turned off cabin overheat as well. Does "data sharing" contribute to battery drain? My phone is also always connected... I don't see an option to have it stay disconnected while I'm at home.
Other than that, I don't get it...why should the battery be draining a few % in less than 2 days if it's not being used? I'm pretty sure it's being used by something.
How often do you check the Tesla app? Each time you do that it wakes up the car.I didn't want to start a new thread so I shall revive this one. My phantom drain isn't horrible, but I've read stories on here about losing only a few % over the course of a week or two. I've lost 2% since Saturday night.
