I know there is a range hit when you remove the covers but don't remember how much (is it about 3%). I'll wait to see the wheels in person both with the covers and without. Then I'll evaluate the looks combined with the range loss.
That sounds like a good plan.Last I read it's about 30 miles? I too prefer the look without the covers, and will prolly sacrifice the 30 miles to go without them (pop them on for long trips of course).
No. They are basically hubcaps. What takes more time is if you get a center cap and lug covers to pretty up the wheels when the aero covers are off... Then it is a bit of a pain to switch back and forth. Speaking from experience with the Model 3 aero wheels, of course, the model Y wheels could be different .I've never dealt with covers. Are they difficult to take off and put on?
It's not 30 miles. The 10% figure was the difference between aero (i.e. Gemini) wheel with covers on vs. the sport wheels. Taking the covers off will result in ~3% reduced range or ~9mi of max range compared to the Gemini wheels with the covers on. This is of course at highway speed. The range reduction will be much less at lower speeds. All this is based on measurements taken on the Model 3, but should also apply to the Y.Last I read it's about 30 miles? I too prefer the look without the covers, and will prolly sacrifice the 30 miles to go without them (pop them on for long trips of course).
On the model 3, you don't need to take the lug nut covers off when you put the hubcap back on. Just pull out the center cap and Pop on the hub cap.No. They are basically hubcaps. What takes more time is if you get a center cap and lug covers to pretty up the wheels when the aero covers are off... Then it is a bit of a pain to switch back and forth. Speaking from experience with the Model 3 aero wheels, of course, the model Y wheels could be different .
"Just pull out the center cap" isn't quite as easy as it sounds. On my 3, I drilled some small holes in each cap and used a hook to pull them out. Other people use a suction cup device.On the model 3, you don't need to take the lug nut covers off when you put the hubcap back on. Just pull out the center cap and Pop on the hub cap.
powder coating - Yahoo Local Search Results"Just pull out the center cap" isn't quite as easy as it sounds. On my 3, I drilled some small holes in each cap and used a hook to pull them out. Other people use a suction cup device.
Hopefully, those bare wheels will look better with the center cap and lug nut covers on. If not, I may be painting the covers or powder coating the wheels. Anyone know where I can get the powder coating done in the SF East Bay?
Thanks,
Cliff
The only ones I like are the uberturbine - the others are no bueno.I'm not a fan of any of the model Y wheels to be honest. I'm sure that will change a bit when I see them in person. I'm planning to get a White or Gray and i think a darker aftermarket wheel is where I'll land.
Try this to get the center caps out. These suction cups work like a champ.
https://www.amazon.com/gp/product/B015T58AUW/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
