I'm new to Tesla but I have this one question
Sebat4
91
35
New Jersey
Hey all,
My Model Y is my first Tesla ever but today I walked up to my car (parked on the parking lot over night) and I could hear a fan going on the passenger side right before front windshield. Is that a normal thing? I thought maybe I had AC going but it was off. I'm trying to understand what that sound is. Does anyone knows what that might be?
dhrivnak
4,389
3,516
NE Tennessee
There are fans that can run to cool the cabin or the battery Depending on temperature and the sun. So if warm not unusual. But if below 60 then likely strange.
Sebat4
91
35
New Jersey
Yeah, it's 93F outside today and the car is parked in the shade but gets hit by the sun for some time in the day. I thought it might be a cooling fan for the car or something. Just wanted to make sure I'm kot freaking out. Thank you for the quick response.
Chisale
210
180
Ohio
Yes. Likely your cabin overheat protection turning on. When possible it will run the Fan only. But if it gets really hot then the AC will turn on briefly too. It will try to keep the cabin in the 90-100 F range. You can turn this on or off on the control panel. It does use up quite a bit of energy if parked in the sun all day and with no window coverings.
Reactions: beezy
Sebat4
91
35
New Jersey
Ahhh I see. I just notice that a battery was at 84% this morning 9am and now it's 82% in the afternoon 3pm. I still have functions to figure out, so new that even those tutorial don't explain a lot. I'm gonna try and move the car into the shade and try to keep it there. Should I have that function on to run the fans if it's a hot day?
HenryFarkas
109
68
Maryland, US
Hey all,
Impaler
'20 MY LR Black/Black, 20" induction w/FSD
Jul 5, 2020
292
131
Also have had my model Y for four days now… I have not enabled cabin protection because it is a energy hog, as others have said. What I did the other day when it was very hot out, was as I left my place of work I opened the app and turned on the climate to get it down to 72°. I actually lost about 3% charge doing that, but for the sake of 10 minutes it wasn’t bad and when I got in the car it was very reasonable.
TomServo
1,075
612
Belleville IL
When Cabin Overheat Protection is enabled does anyone know the UPPER and LOWER temp limits that it will try to maintain. I mean I don’t think it would need to lower the temp from say 130 to your SET temp. Maybe bring it down to say 90 degrees and hold it there. During the summer in some parts of the country that could consume many miles of range.
Feathermerchan
1,098
843
Euless, Tx
See your owners manual. There are at least two kinds of cabin overheat protection. One uses ambient air (blower) and another uses A/C.
I think they both are fixed in temperature.
bpjones
93
106
Houston, TX
Is this function something that isn't bad for the car in a hot weather?
If I understand your question correctly, the feature is designed to protect your car's interior from damage caused by overheating. I’ve enabled it and never worried about the battery usage.
Impaler
Jul 5, 2020
292
131
What if I would just use a Vent option in the app to remove inside air?
That’s a good idea to get the hot, stale air out and maybe if there’s a breeze, to get some air flow in with zero SOC impact. As the other poster above me said, might want to do only 10-15 min before you go to your car after you check the weather.
qingshan
18 lr rwd fsd
Apr 19, 2020
276
127
Pomona Valley
I use that here in SoCal where it's been 100+, w/o AC option for cabin protection but even running ac isn't terrible on charge and it shuts off of soc (state of charge) gets low (20% I think)
Think of the car as semi-sentient, it takes care of itself and runs systems as needed
And welcome.
