steve841
Holy crap! You folks like some chilly weather .. I think we hit 50F last week. Time to salt the driveway?
It is 5F right now and was -7 F last night and we haven't hit February when it easily gets -20 at least a week out of the month. So is it a safe assumption that i probably wont have regen a good portion of the year?
And if cold is so bad for charging the battery packs how does that work in the winter. I plug in my NEMA 14-50 and wait 4 hours to warm the battery before it starts charging? And those stuck on 120 voltage or low amp 220 is the current even sufficient to keep the packs heated and charging in the same boat?
There is: the friction brakes. Tesla should program the car to apply the friction brakes ever so slightly when you lift off the accelerator in cold weather no-regen mode to emulate the behavior of regen. Keep it consistent. No surprises.
Yes but I was responding to Robert's suggestion that 15 minutes of warmup would allow full pack performance out of the gate. Even with use it's going to take a while to warm up, one reason lithium cells are so efficient is low effective internal resistance, i.e. less self heating.Doesn't it warm up through usage?
What if you have a heated garage, and full regen is available? I assume the TC takes care of that.I disagree, in cold weather the last thing you want is to lift off the accelerator and find yourself spinning on ice.!
It's a shame that Tesla gets penalized by ill conceived notions when they have a wait list (not tepid demand) and that the Performance one is on par with the cost of it's competitors, and it's more convenient than going to a gas station once a week.
I took a trip 90.1 miles last Sunday that should have been doable without charging. Close, but doable. Luckily there was an outlet at my destination, so I got to charge up. I did.
I assume you mean 90.1 miles each way, so you were trying for 180.2 miles total, with some time in the middle where the battery would get cold. This should have been easy starting with a range charge. I think that would have been possible even with a standard charge, and without charging at the destination, but even if you only had a 120v outlet, that would have been enough to keep the battery warm while you ate. In that case, 180 miles on the 85kWh is easy.I took a trip 90.1 miles last Sunday that should have been doable without charging. Close, but doable.
85 kWh battery? You left with a full battery? Temperature? Nnot enough details to really understand your point.
he thinks demand for electric cars will be "tepid" until technology catches up and consumers don't have to "pay a premium or sacrifice convenience".
But, for longer drives, it's really not. If you never go outside 80-90 mile radius from your home, you're golden. If you go farther, you'll need to stop and charge. For many here, this is apparently a non-issue, but I think for the masses it WILL be an issue.
I took a trip 90.1 miles last Sunday that should have been doable without charging. Close, but doable. Luckily there was an outlet at my destination, so I got to charge up. I did. Good thing too, the temp dropped quite a bit while we ate dinner and hung out at our friend's house and used up much more range on the way home than on the way there. Had they not had a high power outlet, we would have been forced to stop at the J1772 a local community college had set up. How convenient is leaving after a great night and driving to a parking lot to sit for 1.5-2 hours while you grab enough range to make it home?
Broder? ...Broder...?
Uncalled for.
Agreed. Although he was probably just trying to be funny, that was definitely low.
Thanks for sharing your driving experience. 536Wh/mile seems high. Do you remember how fast you were going? Regardless, even though you made it, you can't deny that there would have been some range anxiety at the end of that trip for pretty much anybody.
I think at this point, most people's feelings are that the "convenience" you get by not having to fill up at a gas station is not enough to overcome the "hassle" of charging and related anxiety on long distance trips - even though they occur sledomly for most people. This should change as more and charging stations and superchargers pop up.
Actually, rereading the BoA comments in the OP, I pretty much agree with them. It appears that current demand may be enough to keep Tesla profitable in the near future, but there is no doubt that overall demand for electric cars will be tepid until the infrastructure grows and matures. Fortunately I think Tesla is addressing the infrastructure issue, and is in a good position to grow as a company WHILE the technology and infrastructure grows.
Whoa, AO! Your average energy usage is like 100Wh/mi higher than mine; never mind doing a trip with 536Wh/mi. I'm not a slow driver but that's surprising.
Like I said, the way there was no problem. Average usage on the way there was around my usual 440. I didn't think to snap a shot until after we ended up getting the car plugged in for a second time (we plugged in, then had to move the car so another car could get out of the driveway), and by then it was gone, but it was around 440. I remember because I was hoping to get 390-410.
