My 70D came without the 2 bottom trunk lights, (top one on the hatch is there) but does have the wiring and the carpet has a half cut area where so you can easily install the lights. I just installed two 5000K SMD LED strips under the plastic rails that hold the parcel shelf up, one on each side, and it lights up everything clear as day.
That's good to know; I'd like to see the photo's too.
By way of an update, the first production candidate should be with me by early next week. The focus so far has been on the tooling (i.e. the injection molding, lens assembly and wiring), so the version I get should be good from a fit and finish point of view, but the LED bulb will likely need to go through another couple of iterations, as there's a few options there. Making good progress though.
Hopefully once you get this tooling and production run going, you will easily be able to provide single-lights for the frunk. I believe the Tesla's light puddles are interchangeable between the trunk, frunk, and doors.
They are
I'd be interested in the additional lights for the trunk, pete8314 (I just have the light on the liftgate). Looking forward to updates and photos when you get the prototype.
Do you have any preliminary thoughts on what'll take to install?
Could you post pictures please? I can't locate the half-cut area you are referring to.
Thanks!
I'm definitely interested in a plug-and-play solution too.
Bought some accessories from your site now.
Ideally almost no effort at all. The replacement lens will be a complete replacement for what the car ships with (lens, power clip and LED bulb), so it'll just be a question of popping the old lens assembly out (easy to do with a finger nail in the trunk), unclipping the power supply from it(there's a small release clip), and then just clipping on the new one and pushing it back into the opening. Very, very easy, no more than a minute per bulb, no tools, splicing or any other modification needed.
Thank you Pete. Without the work you are doing, you wouldn't get such quality products as you have done. Totally worth it!
That's great Pete. I'll take 4 as they are and two later for the trunk.
check your email.
We might end up with a couple of versions (bright and ultra-bright, or something like that); the latter for the frunk and truck, and the former for some of the internal lights where you really don't want anything that's too bright, on the basis it's meant to be ambient. We'll see how the next batch works out.
