In-development: Inexpensive Custom BMS for Tesla Battery Modules
Olle
783
402
Orlando, FL
Fast forward another year, what is the latest on this? I am planning on installing a couple of Tesla battery modules as house back up and would be interested to hear what you all mean are the best bms options for them now.
Reactions: NiallDarwin
Andyislive
New Member
Apr 19, 2018
2
0
West Los Angeles
Why dosent someone just take a simple BMS like this one that charges cells to 4.2v and make each cell group charge to 4.05v. A simple $20 BMS that works on its own is all I need. I have one Tesla 5.2kw battery sitting in my RV doing nothing while I'm using 420watts solar to charge my 12.8v 128watt lithium iron phosphate pack 4s bms. I have double the solar power waiting for the battery to be safe enough to use. I even have the 1000watt inverter 24v on standby.
wk057
Senior Tinkerer
Feb 23, 2014
5,651
11,378
Hickory, NC, USA
The small balancers you see around like the one you posted can work for manual balance management. Many of my RV customers use things like the Tenergy 5-in-1 combined with my JST converter boards (free when modules are bought from me). This way they can set sane voltage min/max on their equipment, and use the small device to manually balance the units occasionally.
You can't use them for high current protection though, not with the Tesla batteries. They're capable of nearly 2000A short-circuit discharge before the cell-level fuses pop... and a little $20 PCB isn't doing jack-s* besides catching on fire if that happens. You need real fusing for that.
Keep an eye out though. I've recently revisited this particular project and have an upcoming product. The 057 Mini BMS.
Reactions: llavalle
L-P-G
351
342
Orlando, FL
EVTV's is something like $2.5k for an Arduino, some relatively cheap hardware, running mostly open source software.
SimpBMS at least isn't a rip off, uses actual custom hardware, but still kind of expensive.
I'm going to have to release something at some point.
Oh trust me I agree, I currently have one and I didn't find out about the SimpBMS until AFTER I had already bought one.
Maybe if the first guy that tore apart a Model S battery pack wasn't such a slacker we'd have a third better option ;)
spaceballs
629
99
Sammamish
Had my intern design a BMS (runs on ESP32 "WeMos" board and "Link Node" board) that connects to the Model S modules and talks to the Tesla BMB's. Even talks to an phone app via bluetooth, if there enough interest I might release it.
PCRover
24
9
NorCal, USA
Definite interest here as I use several of those batteries in my Solar Power system. The BMS I am using seems to work fairly well, but it would be great to see what other have come up with.
EkBuZ
72
35
North Dakota, USA
I think any system that uses the Tesla BMS is the way to go. Why add another layer of hardware, when there's a really good one right there. I'm guessing the Model 3 modules use a different communication and this wouldn't work for those.
BobbyMartin
35
13
Pace, FL
I played with Collin's BMS software, got it to work, but for balancing reasons I moved over to Tom Debree's TeslaBMSV2 (a fork of collin's project).
I took a hard look at EVTV and SimpBMS (also made by Tom), but couldn't justify the cost with all the open source options available.
With some advice from Collin, Tom, LPG, and wk057 I've got a 90% solution working with some small changes I made to TeslaBMSV2. Still a little bit of finessing to be done with the balancing, but otherwise a solid build. If wk057 ever releases his I'll move over to that, Until then, it's all up and running.
You can see the output of the BMS running at LongDog Powerplant
Reactions: SageBrush
PCRover
24
9
NorCal, USA
Are you using one of Tom's boards, or just his software? I am currently using the EVTV system and not real happy with it.
PCRover
24
9
NorCal, USA
Out of curiosity, what's bugging you about it? I have one as well.
The software was crashing at least one a month taking down my system for no reason. Also one of the relay drivers on the board burned out. I tried to get a replacement board but they would only sell me a complete new package at full price, not just the I/O board. I passed on that.
Due to this unreliability I no longer use the relay control part of the system, just the software to monitor the cell voltages and temp's. Currently I am installing my own PLC based battery protection system and will be switching to "Tom's" control board for reading the Tesla BMS data.
