In reverse, suddenly shifts to Park
Discussion in 'Model S' started by GreenT, Feb 5, 2017.
Tags:
  1. GreenT
    GreenT Member
    Florida / France
    Wondering if anyone else has seen this symptom?
    As of yesterday, occasionally, I go into reverse and within feet the car suddenly jumps into Park.
    I thought I must have hit the button on the stick ... but the second time ... nope. And someone was in the car when it happened and confirmed I didn't hit the Park button.
    I am candidly, VERY anxious it could happen in Drive?
    I am already on my 3rd motor but have had no milling noise.
  2. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Maybe the seat sensor? Are you lifting out of the seat at all to look behind you? If not, the sensor might be going bad.
  3. brkaus
    brkaus Well-Known Member
    Austin, TX
    Seatbelt on or off?
    Lifting your butt from the seat?
  4. GreenT
    GreenT Member
    Florida / France
    I wish! Seatbelt on ... no butt lifting .... :(
  5. Saghost
    Saghost Well-Known Member
    Delaware
    If the seat sensor detects that you aren't in the seat at low speeds, it automatically shifts to park.
    As the other posters are suggesting, we've seen some people who reverse by looking over their shoulders lifting themselves out of the seat to do so, and the car respond by shifting to Park.
  6. Manzacoty
    Manzacoty Member
    Dallas
    Is your door open by any chance? Sometimes if I'm moving a few feet and have the door open it will revert to park.
  7. GreenT
    GreenT Member
    Florida / France
    Car door closed. I am looking ONLY at the rear view camera to look back.
    I am just hoping that when traveling at high speeds (> 20?) that Park cannot engage. Wondering if it's a shorting switch on the stick that cannot do its things at speed.
    Then again I was in traffic for the past hour idling along at 1-7 MPH and no issue. Seems only to be reverse.
  8. busaman
    busaman Member
    suffolk UK
    mine does it and its bloody annoying when i am trying to reverse out of my garage which is very tight. but doesent do it with my seatbelt on which is a pain it must think your going to have a fatal crash at 1mph therefore must have your seatbelt on at all times stupid and not thought out but an easy fix for tesla i have asked them to switch it of but they tell me they cant...
  9. GreenT
    GreenT Member
    Florida / France
    My seatbelt is on and the red icon on the dash (indicative of the seat belt being on) is off.
  10. tyson
    tyson Member
    NC
    I have seen this only with belt off and at slow speed with no input to either the brake or the throttle. If I use the accelerator even in the least bit then it will not shift. If I just give a little accelerator then make very little input it will shift back to park. Somewhat strange but it seems the more quickly I move the vehicle with the belt off the less of a problem it has with me doing so.
  11. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    You asked Tesla to remove a safety feature because YOU don't want to wear your seat belt? Hmmm...
  12. legoman
    legoman Member
    Lake Forest, CA
    Happened to me the other day. I was rolling back out of a parking spot (no creep, just gravity) with no press of the accelerator. After about 5 ft, the car shifted to park. I think it's a safety thing to prevent unsupervised rolling. Hasn't happened again since, but normally I use the accelerator to reverse. Only one data point, so just my guess at this point.
  13. ev-now
    ev-now Member
    Denver, CO
    I believe you may not have had the accelerator down, but were instead rolling - doesn't allow you to roll far before it goes into Park
    Edit: Ah Legoman had same thought - sorry was catching up chronologically ...
  14. Az_Rael
    Palmdale, CA
    So, I am guessing this occurs if creep is off and you are rolling just due to gravity? When I back out of the garage, I am riding the brake pedal, since creep is on for me. Never had the issue, so maybe that's why? Learn something new every day here.
  15. ev-now
    ev-now Member
    Denver, CO
    Yep, we certainly do not have creep enabled on ours. @GreenT can you perhapas test with/without creep? And/or do you know you use gravity/momentum when it kicks into Park?
  16. busaman
    busaman Member
    suffolk UK
    Basicly yes BUT im not stupid enough to drive witout a seat belt, im also not stupid enough to need gongs or lights to tell me im not, (most european cars let you get to a t least 15mph before it nags)
    and what is safe about reversing out of my garage down a slope with mirrors folded in (to stop breaking them off) being very carefull not to damage my car and the stupid thing decides it wants to go into park every 3 feet??? with no overide to stop it.
  17. GreenT
    GreenT Member
    Florida / France
    My creep has always been set to OFF. Love that feature.
    I have been backing out of the garage the same way for a year. Touch the accelerator to get it going, then let car roll before stopping to turn right to get out of driveway.
    I did upgrade firmware a week ago to a bug release that I'd been holding off on. I suspect it might be a new, undocumented, "safety" feature? I have the Classic S with no sensors.
    Does creep even work in reverse? Testing? Problem is I'd have to keep creep on as the problem is intermittent. Happened 3 times in 4 days.
  18. rowdy
    rowdy Member
    Australia
    Yes, my p85 suffered this issue or something very similar when my dad was driving. Ended up with the car stuck on the street unable to move (luckily not a busy street).
    The following report was given to Tesla:
    "Saturday 7th January 3.30pm, air temperature 36 degrees. Car had been in
    sun for 3 hours after a 2 hour drive most of the time at 100 km/hr. I
    reversed the Tesla S P85 for approximately 30 metres down a
    driveway to the street.
    Car was across the narrow street at a 45 degree angle. Tried to put car
    in drive and nothing happened. Screen showed car in park. Would not move
    out of park. Moving the right hand lever on the steering column had no
    effect. Message came up on the screen asking me to move the lever into
    the D or R position. I did that repeatedly to no avail. Reset computer
    by holding down both scroll buttons, then realised that did not reset
    the car. Thought the brakes may have locked up. Got out of car and with
    a neighbour gently rocked the car. Went back inside the car and noticed
    it had turned itself off. Put foot on brake, car turned on and operation
    of car returned to normal."
    Tesla couldn't find anything in logs. Car has been suffering DU bearing noise and they are swapping the DU next week. Hoping this is a one-off.
  19. Az_Rael
    Palmdale, CA
    Yes, creep works in reverse, that's actually one of the main reasons I keep it on. Easier for me to back out of tight spaces with the brake pedal vs the gas.
  20. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    Keep your butt in the seat and use the screen for your reverse view. Also, wear your seatbelt.
