New Model Y owner here. I've noticed that sometimes my car coasts more and other times breaks pretty firmly when I lift off the accelerator. Although I changed driving settings once, I didnt touch the braking settings. But I've also noted differences on the same settings. It seems dangerous to have the way your car breaks be inconsistent, no?
It’s the weather and your battery temperature. Try pre-conditioning the vehicle for 30 minutes before you drive it. Even then, with temps in the Northeast as they are, you will not get 100% regen until Spring/Summer.
I believe the regen braking turns off if your battery is charged greater than 90 percent....is that what happened/ R
It doesn't turn off. It's reduced. OP, it's because it's cold out. Also...brakes. If it's breaking then you have a bigger problem.
Any good engineer wants their system to break consistently, so its easier to diagnose. But if braking is not broken then breaking consistently is not an issue so the system is not breaking and inconsistent braking is working as desired.
What ^^^ they said. It's all spelled out in the Owner's Manual. (Good luck SEEING the regen dots on the power bar. Hopefully the visibility of those dots will improve with an update.)
Ever since my first Tesla in the olden days (2014), I've thought they should just use the mechanical brakes to simulate regen when regen is not available. keep the foot off brake pedal slowing consistent. I'm sure the post is around here somewhere.
I'm not sure you'd want that. The interface required would be too complex, IMO. We're already seeing the folly (and danger) of FSD, because of the infinite number of scenarios with lane design, construction zones, etc. etc.
the interface wouldn't be impossible but would make the driving experience more consistent if it just applied the brakes slightly to always slow down by x/mph/ps, if it happened by all by regen then no brakes required, if it's not slowing down fast enough then add more brakes. Although i find this is only an issue when you first get a Tesla or are lending your Tesla to someone, if it's your daily driver you tend to just learn the behavior and react properly.
Does no one else get the warning message about reduced regenerative braking when the battery is cold?
Casmium: I find the car exceptionally linear and smooth, using only one pedal regardless of the regen input. That's actually driving the car, not using any FSD nonsense or cruise control (clearly, I have an opinion on this! HAHA!!!)
Yes, I get the regen reduced message a lot during the winter. That does dramatically affect how much regen you get when you release the accelerator. Also discovered once that the regen menu setting got changed to low. Not sure if that was from a software update or not but took me a few days to discover that. Now back to Standard Regen. Since it is cold, I do try to warm up the car for 20+ minutes before I want to leave (if I remember). A warm car = a happy car + a happy driver + more regen capability For those that aren't sure what dots people are talking about, I provide this (from last year's software): Of course, with the new software version, the dots are smaller and harder to see.
Ok makes sense. While it seems like a consistent driving experience might be desirable understanding that the car will self break (sic) less at the start than when warmed up helps immensely! I do see the braking reduced message sometimes, but I haven't been able to map it to how the car feels.
