Hi All,
My 2020 LR was recently in service for front half shaft replacement ( usual shudder problem ). After service I am experiencing elevated wh/mi values. I understand in winter its bit higher but current values are above that. On highways where I used to get around 300 now same is 400+. Anyone experienced it ?
Same exact issue
lost 30% range after new tires and half shaft replacement
Performance model x 2020 25k miles
I just had the service bulletin done for the half shaft replacement along with new tires in Oct 2022.
I noticed ia needing to charge more frequently... Then started paying attention to my watt's per mile.
Used to be 297wh\mile to 330 or so typically. Average was just over 300wh\mile since owning the car. Which matches the 330 mile range
Now it is almost 400wh\mil average and when I just pull out of the drive way, I've seen it jump to 1400 w\mile for the first mile. In chill mode. Range has gone to crap.
Any one know what might have happened? The service has been horrible at our Tesla dealer and in afraid of I put in a service visit it will be a long ride out there with no result.
Would love to go in with a recommendation for them.
Anytime else have this happen with new tires or the half shaft replacement. ? Side note, when I left the alignment was bad and had to return 2x for then to get it right. Not sure if that was related but add ing for detail. Alignment is good now.
This is not temperature related
I've had the car for 2yrs and the w/mile increase is new
