Induction Stoves
Kuhz
1,907
2,111
Mars
I wanted to remove our Thermador cook top and install an induction unit, looked in to this years ago but most of them require a 240v 50 amp circuit breaker and have no more room in my MSP. Could do the portable unit not sure it is worth changing the pots and pans.
Our thermador induction will run on 240/30A. Look around at different models
Kuhz
1,907
2,111
Mars
Induction cooktops are great, we replaced our regular electric with one. However as most things in life, quality units are very very expensive ($2k and up). I suggest to steer away from cheap units or you’ll get blamed by the friends wife because of the poor performance of that unit. And you don’t want that.
Reactions: abasile and Dave EV
SageBrush
REJECT Fascism
May 7, 2015
12,902
17,229
New Mexico
Also something to be considered - the video in post #8 points out that cooking with NG decreases indoor air quality. Would like to see some hard numbers on this as this would be another selling point.
I don't doubt the drop in air quality, but I'm a lot more inclined to think it is from the cooking per se and not NG Vs electric/induction.
This must be even more true in my home since we like charred food
Am I wrong ?
nwdiver
8,589
11,978
United States
There's this article from Vox covering a recent study.
Gas stoves can generate unsafe levels of indoor air pollution
Am I wrong ?
It's the gas. The worst pollutant appears to be NO2. You can't get NO2 from cooking food... even if you like well blackened ;)
Cooking food appears to lower the levels with gas stoves since you're cooking food instead of cooking air and NO2 comes from cooking air (at higher temperatures than you get from electric)
Reactions: abasile and iPlug
SageBrush
REJECT Fascism
May 7, 2015
12,902
17,229
New Mexico
Down the rabbit hole ..
https://www3.epa.gov/ttncatc1/dir1/fnoxdoc.pdf
They point out that NO2 is a pollutant due to its interaction with light to produce tropospheric ozone. I'm not sure but that sounds like a reaction that takes place outside.
I'm not sure that your conclusion is correct about charred food. It is true that charred food does not emit NOx, but if I am understanding correctly, the higher the cooking temperature, the more the NOx
iPlug
657
967
Rocklin, CA
Am I wrong ?
This is all new to me as well. Haven't stumbled across this or had much thought on it until this thread; nwdiver data above is the first I've seen.
IIRC you mentioned in the past having concerns for indoor air quality and the importance of heat exchangers to help manage this without losing the insulation envelope of the home. In your case, sounds like still not a problem.
SageBrush
REJECT Fascism
May 7, 2015
12,902
17,229
New Mexico
Yep, although I was talking about CO2 and humidity. I don't really concern myself with cooking related emissions since we ventilate the kitchen for a few minutes after charring cooking.
SageBrush
REJECT Fascism
May 7, 2015
12,902
17,229
New Mexico
^^ Google found some reports of lung injury from NOx in the ppm range. I have not read details yet.
Your cooking table is in the ppb range
Fwiw, I have fairly reactive Asthma and have never been bothered by routine cooking. Even our episodes of turning the kitchen into a plume of smoke have not resulted in an asthma attack.
Reactions: Dave EV
SageBrush
REJECT Fascism
May 7, 2015
12,902
17,229
New Mexico
Yeah. I think WHO recommends <20 ppb for chronic exposure. Which is why if you have a gas stove you need to run your vent hood when you're cooking.
That 'chronic' exposure is a high bar. Makes sense if you are cooking most of every day
I'm not sure it applies to routine family cooking, and even less so if a kitchen window is opened for a couple minutes
nwdiver
8,589
11,978
United States
Depends on how well ventilated your house is. If NO2 levels go to 100ppm when cooking breakfast would they be <20 by dinner time? If they go back to ~100 when cooking dinner would they be <20 by breakfast the next morning?
SageBrush
REJECT Fascism
May 7, 2015
12,902
17,229
New Mexico
All good questions. I'll add that I don't know if the measurements you posted earlier are average in the kitchen, or just above the frying pan.
