Indy to Effingham in a 60?
Discussion in 'Midwest/Great Lakes' started by Rifleman, May 18, 2015.
  1. Rifleman
    Rifleman Now owns 2 Model S's!!!
    Harrison Ohio
    What does the hive mind think, is it advisable to try to go between Indy and Effingham in a 60? The two stations are 145 miles apart, and I think the terrain should be fairly flat, but being that this will be the longest single leg I have taken in my car so far, I am of course a little nervous, particularly as there are essentially no "divert point" chargers along the way if I get myself into trouble. Has anyone here made this trip in a 60 yet?
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I wouldn't think that would be an issue. Start the trip off in right lane at 65mph and have an RV park as backup maybe. Use Nav with trip prediction too.
  3. MyJoule
    MyJoule Member
    Tucson, Az
    EVtripplaner.com says it will take 153 range miles at 72F so, unless you drive very aggressively, or the weather is very poor-( cold and/or windy) you should be ok even in a 60 if you are going from the Indy Supercharger to the Effingham Supercharger. Keep in mind that you should try to make sure your charge is full when you start and as dsm363 says, start out the trip driving under the speed limit. Also, having just come through there last week, there are plenty of places in Illinois where the speed limit is reduced due to road construction so that will help. Good luck.
  4. GSP
    GSP Member
    I thought plugshare would show charging in Terre Haute, but Terre Haute and the entire route is a charging wasteland.
    However RVparking.com shows several 50A locations, including next to I-70 in Terre Haute and Casey, IL. I would call ahead to see if they would allow you to charge, some RV parks can be full, or just have inconsiderate owners. You shouldn't need it, but it is always good to have a plan B.
    GSP
