[INFO] Maximum TV Size in Trunk?
Jedi2155
Model 3 has Arrived.
Jul 6, 2018
1,685
1,441
Upland, CA
Hey, I'm a Black Friday loving intense shopper for years and one of my few yearly traditions. Looking for a TV for my sister and wanted to confirm if a 65" fits in the trunk?
AFAIK Model 3 Dimensions are as follows:
Trunk dimension:
Width : 37 inches - 94 cm
Length : 42 inches - 107 cm
Height : 18 inches - 46 cm
Specifications for a 65" TV top out around 35.9" but I'm assuming that's without the box
Wanted to confirm if anyone has actually tried it. I think I heard a 60" fits no problem but don't recall if a 65 fits.
Jaywlker
Former Vendor
Nov 8, 2018
287
194
North Scottsdale
Trunk dimension:
Good luck! I’m just posting so that I can later learn the result.
WARP 10
176
115
San Diego
Trunk dimension:
Pythagoras says just short of 56" on the diagonal.
hd-2
59
123
Midwest
I dont think it will. The box on a 65" is usually 40-42" wide, so even though it will fit in terms of depth (with the seats down), it can't make it past the narrow opening above the wheels. That tops out around 37" so my guess is unless the TV is shrink wrapped instead of boxed, it's not going to fit.
Reactions: P85_DA
Jedi2155
Jul 6, 2018
1,685
1,441
Upland, CA
Well I measured the box to be 37 and a quarter inches tall. The side skirts of the wheel well flexible and it fits!
Its a SUPER tight fit so don't necessarily recommend it wasnt so tight that it damaged anything, still was able to slide out.
animorph
2,161
1,584
Scottsdale, AZ
I'm jealous! I picked up a 65" TV with my X (6 seater) and had to let about 6" of the length hang out the back with the hatch open. At least the exhaust coming through the rear didn't kill me.
Reactions: Watts_Up
Jedi2155
Jul 6, 2018
1,685
1,441
Upland, CA
View attachment 355468 Okay it fits perfectly. I felt like the car was made to pick up the 65” car.
Lovely! Was that the $400 65" TCL? I ended getting a Samsung 65NU8000 for $860 at Fry's. I did consider the TCL due to the support for Dolby Vision which I'm not sure the Samsung has (still in the box ATM).
Someone else said their 65" didn't fit though....
kaidou
212
94
Raleigh, NC
yes exactly! I am not a TV person and this was my first time buying TV (hehe). With the trust I have from TMC community, I went to the Walmart with Model S! For us, this TV suffices all the purpose. We are not TV enthusiast.
It fits perfect, and I highly doubt that bigger version like 75? would fit. Mine is Model S.
Jedi2155
Jul 6, 2018
1,685
1,441
Upland, CA
According to this, the Model S only has an extra inch of width compared to the 3. I measured the box to be 37.25", while the uncompressed width of the Model 3 was 37". Only with compression was I able to get the extra 1/4".
Reactions: longshot49
kaidou
212
94
Raleigh, NC
Well in my case, it was "perfect fit" to the width of the trunk. so in an inch difference will not let it fit. The worst case scenario is to unbox it :)
Hope it works!
Reactions: Jaywlker
Need
3,044
2,352
Rancho Cucamonga
The box doesn't have to lie perfectly flat on the floor right? I think if you put some pillows on one side under, the diagonal width will be at least 5" wider... probably could fit a 75"!
Reactions: Watts_Up
Lifeinabox
701
523
Los Angeles
I find this timely and fascinating as I have TCL 65” waiting to be picked up. Was going to take our minivan but now tempted to take the S for the challenge.
