CertLive
$2000! That doesn't even cover the labour costs on a combustion engine to get most cars to do that speed!
Is the P/AWD power difference just a software unlock? I remember the 980 P parts vs the 990 AWD parts debate, but I don't know if it was ever firmly resolved.
If I recall correctly, the difference in hardware for my 2020 stealth from a plain lr awd was the power inverter on the rear motor. Basically capable of dumping more power into the motor. Think the motor itself was the same, but since the whole motor assembly including the inverter had a different part number everyone thought the motor itself was different. I’m guessing they just weren’t selling as many performance cars so had a fire sale on stealth options (think mine was $2000 extra...easy choice).
Looks like Electrified Garage has cracked the code.
Currently in Beta Testing. Roll out in 1-2 weeks.
"Ghost Mode" will be $2000.00 and will turn your LR AWD into a Stealth Performance 0-60 3.1 seconds.
Unfort right now seems you have to ship your car to New Hampshire unless between now and then they come up
w a way to do ECU reflash out of the car so we can mail it to them then reinstall. Or even poss buy some sort of re flash tool w the loaded software like some companies offer (apr tuning). They also state it can be returned to stock settings.
Take my money!!!
If you follow their youtube channel you can see where they turned a 75d model s into a p100d and uploaded the source code into the vehicle and worked perfect. Even displayed P100D on the dash and cluster.
surprised this isn’t illegal since they are using modified Tesla code (which is not illegal) but then they are selling that code, which is...
You must have never needed to take your car into the service center.
Of course Tesla will find out what you did. when you do. That's a no-brainer.
Lastly....there is about to be a total software rewrite update coming. Good luck keeping your $2k Performance software. Will you have to send your car back to them AGAIN?
hack the supercharging back into working
I would be curious if this remapping would mess with TACC acceleration curve, and how things like Summon would be affected.ARE they? Evidence?
The suggestion was it'd be a man in the middle device. Meaning they're using 0 tesla code.
Instead they'd be intercepting a CANBUS signal that says "provide 100 units of power" and then sending on "provide 120 units of power" as a replacement.
Again if this is just sitting plugged into the CANBUS, it's not changing anything when not in active use. So you just unplug it before service.
(that's based on the very very very little detail given so far so may not be correct- but it's what we've got)
THAT said- SC doesn't even matter- Tesla could trivially add code to the whole fleet that checks this during operation and reports it back to them remotely.
Utterly irrelevant.
It's the autopilot/FSD code being rewritten, has nothing to do with amping a canbus signal for "how much did driver press the accelerator" or "How much power to the motor for accelerator position X when driver commanded"
Jailbreaking a $800 iPhone is light years different than jailbreaking a $60k car.
Most people can squeeze out another $800 for a phone in desperation, however......a $60k car....not so easy.
Just a quote from page 8 of the warranty above where it will be voided if:
