You're so lucky to have the 980 motor. EnjoyJust updated my Boost 50 to Ghost. Frickin awesome.
Yes. Mine is one with a blank plate, so I wasn’t sure. But it’s an Oct 2018 build, so was pretty confident it would be 980.You're so lucky to have the 980 motor. Enjoy
I think you just solved my question. I have an 2018 as well with the same build date and my plate is blank. I think I have the 980 motor, but now I think you confirmed it lolYes. Mine is one with a blank plate, so I wasn’t sure. But it’s an Oct 2018 build, so was pretty confident it would be 980.
The peddle responsiveness is a nice update, but need to get used to it. Just so much power at the slightest touch. My efficiency is already suffering.
Depends on the month…I’m an August 19 birthday and I did not have the full fogs. You should be able to tell just by looking. The led will be in the corner (opposite side of the turning signal led)Does 2019 model 3 come with physical fog light?
Sure - ingenext, occasionally, will release their own firmware update for the specific module you own (bonus, boost sr, boost 50, I believe ghost too, but not 100% on that)Can you give more details on this? Is there actually a firmware update that gets pushed to the Boost SR module? I can find no information whatsoever about the USB-A connector usage.
I think there are a few different 12 builds floating around. I was teased with 2022.12.1 about 5 days ago, but it wasn’t safe on ingenext, so I waited, then it went away and never returned. I got notification for 2022.8.3 about 2 days later, which I updated to and am on currently.2022.12.3 ???
I got upgraded to 8.3 and then 12.3 yesterdayI think there are a few different 12 builds floating around. I was teased with 2022.12.1 about 5 days ago, but it wasn’t safe on ingenext, so I waited, then it went away and never returned. I got notification for 2022.8.3 about 2 days later, which I updated to and am on currently.
I’d really like the 12 build series as it brings back the wiper and defroster cards to the main screen, finally.
Do you have ghost or boost? Any issues?I got upgraded to 8.3 and then 12.3 yesterday
I have neither as I'm waiting for the Razen module to be released, I was just stating that the rollout of 12.3 is underwayDo you have ghost or boost? Any issues?
The new graphics chip is currently unsupportedWhat is that?
I'm shocked that Ghost or Boost or whatever knows or cares about the graphics chip, hence my confusion.The new graphics chip is currently unsupported
RyzenThe new graphics chip is currently unsupported
Depends.. my 2019 is a September build.. no fog lights. I had to swap them in. But earlier 2019s apparently have them.Does 2019 model 3 come with physical fog light?
you will have to check. look thru the wheel at the motor and look for a plate. It will have a number with 980 or 990 in it. Ingenext has a video to show you how to check. Wishing you luck finding 980 motor.What's the cutoff for the 980 motors? I have a Jan of 2020 build, is this a 980 or 990 motor, or unsure?
i've seen the cut off around late 2019 so that's a tough one. Yeah check the plateWhat's the cutoff for the 980 motors? I have a Jan of 2020 build, is this a 980 or 990 motor, or unsure?
