This is the only car forum I've ever been on where the concern is more for the feelings of the manufacturer than the knowledge of how our cars work and perform. I guess it's the nature when there's so many investors and "non techies"/car buffs in the mix, but seriously, we've been given some cool insight, and most of the posts are debating whether or not the poster will get in trouble for sharing.
If he does, he does. I'm the meantime. Lets dissect!
Hmmm the MVPA agreement specifically stated you agree not to reverse engineer the vehicle. I would consider this a breach of contract and thus liable for damages.
Roadster or Model S?
Excellent! Presumably this is an 85 kwh battery.
The next issue is going to be the control protocols for the battery. If third parties are going to be able to reload these with new and/or higher power cells they're going to have to reverse engineer the communication link between the battery and the car. Hopefully Tesla didn't encrypt it.
...Presumably this is an 85 kwh battery...
You can be quite confident that every major car manufacturer has, or soon will, tear these things apart to see how they work. Next will be the hot rod and performance folks. If Tesla sells enough of them, you can also expect that there will be an aftermarket develop for replacement and upgrade parts. Bought a 60kw car and after 5 years want it to be an 100kw car? If Tesla won't sell you the upgrade, you can bet someone else will. Saleen, Rousch, NAPA, and all of the boy-racer speed shops have been doing it for years with varying degrees of factory support. The aftermarket for performance and upgrade parts is worth billions of dollars and employs 1000s of people. All of those businesses and people are not going away because we all decide to drive EVs. Also, there are laws that protect the industry's ability to sell these aftermarket parts. Most important, it's human nature to take whatever we have and make it faster. It will be fascinating to see what develops in the future.
Homer Simpson - In This House We Obey The Laws of Thermodynamics - YouTubeThe thing is, Tesla could already make a crazy supercar version of model s. Assuming peak current draw is already near the max for these cells, just wire the pack differently (in parallel) to double the current output, beef up the electronics (and whatever else) and put in a 900 hp motor. In fact they might as well offer this as an option since a 40kW battery already is. It'd probably need to be 2-motor AWD though, with that much torque...
No matter how you wire up the pack, each cell is going to see the same current for a given power draw.
Well, no. You can also think of it this way. 2 cells in parallel give you twice the capacity because the current is now half thru each--voltage & power staying the same. Perhaps you're thinking of capacity, which doesn't change no matter how you wire the cells (obviously) (Though higher currents will effectively lower capacity because of higher power losses thru heat).
Correct. You cannot "wire differently" to be able to get higher discharge rate without reducing voltage.Well moving batteries from series to parallel will double you current (I), it will also half your voltage(V), and give you no power (P) gains. And P=IV shows this. half V and Double I and you get the same P.
+1 I was thinking the same thing myself. I don't recall ever seeing debate like this when the new iPhone is dissected and broken down into costed components (and we all know how Apple can be!).
