  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Install speakers to trunk liftgate on standard system?
Also interested.
I took a bit of the lift-gate apart to install a rear camera. I did not see any wires in mine.
I really want to add the two (l/r) speakers in the dash and a sub to the standard sound as it is a little plain. Not motivated enough right now as my garage is very cold to work in.
JPP
3,081
1,337
SF Bay Area, CA
Have anyone done it? I heard there could be wire already?
The connectors and wires are in fact there, but your audio amp up front won't have the proper outputs. You will need more than just speakers....
- - - Updated - - -
Also interested.
You have to remove the entire inside plastic trim piece that contains the speaker grilles. To remove this you need to remove the top plastic bar (top of liftgate window) and the left and right side pieces (...lots of blue clips). The large bottom piece is held by a lot of clips plus 2 Torx screws. You have to unsnap the recessed plastic hand holds on the lift gate and also pop out the power liftgate button first. And when you start to drop this large trim piece, watch out for some short wires. And if you enjoyed this, just wait until you try to reinstall this large unwieldy piece--it's a 2 person job for sure. YMMV.
