Aroham sells many yoke styles, shapes and finishes, so choices are many. I chose this more rounded yoke, as compared to the Telsa OEM yoke in my MS Plaid.
My Aroham Yoke
I ordered the one with the same vegan leather as the Plaid, and also the heated option, as my MYP has a heated wheel from the factory. It took only two weeks and two days from order to delivery – Pretty good or a China sourced product.
Installation:
Impressions:
Another great thread on this subject to review is this one. I've also included a lot of pictures of the disassembly and reassembly of the wheel and new yoke starting here.
Questions welcome!
My Aroham Yoke
Installation:
- Open all doors and roll down windows
- Turn off the car, via the UI in “Safety” tab.
- Disconnect 12v under Frunk cover. I have a biodefense MY, so it took a little more effort to get to 12v battery than, say, a Model 3.
- Disconnect the HV main pack connector – located under the rear seat on the passenger’s side
- Using two Allen wrenches, pop the air bag
- Remove airbag module and other connector carefully. Note that the connector tabs need to be depressed before trying to pull the connector
- Using a breaker bar, remove the nut securing the wheel to the car; rock wheel until loose and remove.
- Since I have the heated option, I chose to reuse all of the internal guts of my OEM Wheel, including the face plates. I also have to remove the heater tape connector from the OEM wheel and reused it on the new yoke (I used a soldering iron, heat gun, shrink sleeving and electrical tape to produce an OEM quality connection
- Install new Yoke assembly in reverse order
Impressions:
- Quality of yoke is the same as Tesla OEM, as they start with the Tesla wheel core. Every yoke is custom made and Aroham provides pictures of your specific wheel before shipping, to make sure it meets with your satisfaction
- The Plaid’s yoke is wide, and blocks the lower left corner of the main screen. This more rounded and less wide yoke does not block the MYP’s main screen at all
- This yoke has higher upper tips (aka, nubs) than the Plaid; more to grab and hang on to. Need to go a little more side by side driving to confirm this is actually better than the Plaid’s shorter nubs.
- Since I’m very used to the yoke from my Plaid, I have no concerns driving this yoke, as compared to the Plaid’s.
- This yoke is nice and thick; very comfortable. I believe it is a bit thicker than the Plaid’s, and is quite heavy.
- I do like the yoke stalks combination better than the Plaid’s yoke and all controls on the wheel face – including the F’n horn button.
- Definitely prefer this new yoke’s horn; which uses the Tesla airbag as the main switch. The Plaid has a tiny button on the right side of the yoke that you have to find and press in an emergency.
Questions welcome!
