I have had three done recently. Two in Reno, NV one here in Auburn, CA. Here in Auburn, I had a
Tesla "Wall Connector" installed. It's on a 60 amp circuit breaker, and is a fairly long run, with an added breaker box so I can turn the unit off. The Tesla Wall Connector costs $500.00. To have it installed here, it cost me another $1,200. This one was the most expensive of the three, but it is also the longest and most complicated run of them all.
At another one of my houses, in Reno, it only cost me $700.00 to have the $500.00 "Tesla Wall Connector" installed. This is on a 240 VAC pull-out disconnect switch, right next to the "Wall Connector" the type of disconnect switch that is often used on home air conditioners.
It's not really necessary to be able to turn these off right next to the wall connector or outlet, it's just the way I want mine.
If you want to charge a Tesla at the full 48 amps, (~42 MPH of charge) you must have it on a 60 amp circuit breaker and wiring as there has to be a 20% safety factor for such a 48 amp load.
At my third house, which is only 20 miles away from the house mentioned above, I mainly only want to charge my electric motorcycles from a 240 VAC outlet, which I had installed in the garage, with a fuse panel that I purchased so I can turn it off right next to the outlet. This was a very short run, because the house fuse panel is just on the other side of the wall. This only cost me $500.00 total, plus the few bucks I paid for the extra panel and breaker.
-Don- Auburn, CA
