usofrob
Out of curiosity, do you have an estimate for the range difference with and without the trailer and ATV?
Thanks very much for posting this, xpitxbullx! Could you please clarify what is visible of the hitch when you are not using it? And how big a drill is it to remove however much of the hitch that can be removed?
Thanks!
Pretty much everyone who has one leaves it like this when not in use. Removing this piece can be done but it’s tedious because of the confined space you have to work with while using a wrench.
Let your carwear it PROUDLY, like a badge of honor!
Thanks for the information. With the increased number of supercharger locations, it seems less important to have max range all the time.I haven’t made any trips further than a few miles from my house but for that short distance and I definitely wasn’t going slow and AC on full blast being I live in Vegas.
With the trailer and ATV -about 235 mile range. Proper driving could probably take that well over 250+ miles. Without the trailer about 280.
So a quick guess would be it cuts into my range about 15%
How is the ground clearance? I don't plan to ever remove the insert, but also don't want to be scraping it on the ground going in and out of driveways.
Awesome Thanks! I was considering the 1.25" insert, but if ground clearance seems fine, I would prefer to just use the 2" since our other car has the same hitch size and we swap the bike rack back and forth.
Hi there, if I understand correctly you are tapping into the wires of the rear lights directly, without any electronics module or the like? Is this still working well for you, or have you had issues?View attachment 309974
Installed an Eco Hitch on my M3. I also wired a 4 prong harness for about $25 in parts. The wiring is also completely hidden. It accelerates like I’m not pulling anything. The trailer has standard bulbs and works fine but I’m going to switch them out for LED.
Does the Model 3 detect malfunctioning tail lighrs? Does that still work for you?
I know Torquelift Central and Stealth Hitches sell wiring harnesses, but for sure these are for geared towards US Model 3s, where I aim at installing a hitch on an EU Model 3. Wanna use it for a bicycle rack only.
Many thanks.
Back again ;-) I understand the reason for applying the nylon washers (I bought a StealthHitches hitch and they provide rubber washers, not sure I am a fan of that). But I was wondering about the crossbar. Is that steel or aluminium? If aluminium, should that not be protected as well?It’s an Eco Hitch. I used nylon washers supplied with the hitch. I would have preferred a pad.
BTW: any idea how thick the nylon washer were? In case I wanted to add them myself?
Thanks!
True gold (uh steel). Thank you!The crossbar (on both the Torklift EcoHitch and the StealthHitches hitch) are steel with thick powder coating. The entire rear end of the Model 3 where the crossbar attaches is aluminum. The thick powder coating and nylon washers should keep the steel and aluminum separate.
Here are the approximate dimensions as I measured them from my EcoHitch nylon washers:
thickness: 1.55 mm (0.061 inches)
outer diameter: 38.25 mm (1.506 inches)
inner diameter: 12.40 mm (0.488 inches)
No issues at all. Pulls my ATV and trailer like it’s not even there (1050 lbs). I was careful to make secure connections when I wired the harness. Everything is performing perfectly. I’ve recently changed the bulbs on the trailer to LED to reduce the load even thought the incandescent bulbs worked fine while they were still being used.
I do recommend getting a hitch mount with a d-ring to fasten your safety chains. My previous setup on my Dodge Challenger has the hook rings on the hitch’s main body.
He probably welded it himself or had somebody do it. I tried very hard to look for a similar one and could not find one at all. So I purchased a safety chain loop and will weld it onto my Ecohitch. This picture shows how I will do it.Where did you purchase this from? thanks in advance.
