Pictures are in reverse order.
Star
was it hard getting that bolt off?Pictures are in reverse order.
Start in the back and work your way forward.
I can answer any questions
It quiets the overall cabin a lot.For those that have the parcel shelf, does it reduce the crashing noise of the rear end when going over bumps?
Tried pulling it down after listening the trim on the bottom and side near the windows everything was loose but can’t get that trim piece out of the plastic tophaving a big problem getting the head liner loose at this part
Watch the headliner removal video. Just did it a few minutes ago. It pops down if you giggle the part around.Tried pulling it down after listening the trim on the bottom and side near the windows everything was loose but can’t get that trim piece out of the plastic top
I was jiggling and it’s like stuck on it won’t even budgeWatch the headliner removal video. Just did it a few minutes ago. It pops down if you giggle the part around.
Pull down lightly on the headliner and twist the part up towards the back of the car. Through the open hatch.I was jiggling and it’s like stuck on it won’t even budge
I just finished up my install after picking up the parts this afternoon. I can confirm the revised part numbers listed above still work with the old base trim.I once asked the same question.
The lower c pillar, how do you get this loose?Finished! The install task was 3 out 5 if you like playing with Legos and you have the right tools. I'm going at this blind just by videos and what people have said on the thread. I completed the project in about 2.5 to 3 hrs. The biggest part for me was the lower C pillar and lower seat cover thing.
I started with the left driver side. Figured this had the charger and 12v attachment so it took a little more finesse. What everyone said about the lower C pillar is true it's a pain, but once it's removed the access to the seat belt bolt is super easy (socket extension is needed 6in min. 10in is good) Note make sure you remember the orientation of the seat belt, it's keyed so it can only go one way but make sure you tuck it under the carpet then place the plastic over the carpet or else it makes a rubbing noise added to your other creaking noise in the car.
Install tips:
Watch the video of the guy tinting the roof, and read the install for the CCS adapter to remove the lower C pillar.
1. Lower C pillar in the front by the seats will have 2 metal clips with locator pins. These are a pain to remove. Tug enough around them and you can pull the one on top. The lower one is very hard, just place your hand close to the pin and hulk it and the sucker will pop out. The rest is held on by the upper c pillar.
2. Trick for upper c pillar separation to prevent the clips from falling. Slide you hand in between the separation and when you get close to a clip push in the top c pillar and swiftly pull on the bottom c pillar.
3. Once the lower C pillar is free you can remove the seat belt bolt. The bolt does have Loctite. You will feel the resistance when unbolting. Make sure you add Loctite again before installing.
4. Take a pic of the seatbelt placement so you remember how to reinstall.
5. Removing the upper c pillar use swift tugs to free the plastic clips-, I took pictures of each pin location. same for the passenger side.
6. Where the c pillar meets the roof liner by the trunk hold the liner and tug the c pillar.
7. Wiggle you way out of the rear door roof liner.
8. Freedom!! well almost remove the seatbelt guide, dont break it you need it.
Remember it's always easier uninstalling 🤣
Picture time. I took pictures of where the plastic white pin connectors will mount to the frame. So when you install the new c pillar you can place your palm at these locations and pop them in.
I made a video of the passenger side install, I should have it up shortly.
Thanks for the help everyone!
I went thru the exact same thing w the Rockville locationMobile service came today and installed the upper to trim pieces and the parcel shelf itself.
I had called them and asked them to replace the lower trim pieces for me and they brought those pieces… When he got here he was able to get the glue off from the aftermarket trunk cover and asked me if I wanted him to install the top two trim pieces and the parcel shelf.
Gotta love the mobile guys because they’re willing to do a lot more than the service center will
If you mentioned the word "retrofit" in your initial message, then that's your issue. You need to clearly state you want these three parts, which are not VIN locked. That's it, any more information and they'll probably say no.I went thru the exact same thing w the Rockville location
Like others have mentioned just supply the part numbers in the app, I had mobile even drop the parts off, the less they know the better. Just verify on your invoice the got the correct parts, the bolt people mentioned replacing are totally re-usable so don't bother ordering those just put a little loctite on them when reinstallingIn my case…
I gave the SC the specific the part numbers I wanted and then told them that if they felt like installing them for me great, otherwise I just wanted the parts.
afterwards they seem to have decided to cover their asses by telling me they don’t the install, as opposed to being honest with me in the ticket and saying we didn’t order the parts that you requested. All while attempting to cover that up…. Which they \then got called on when I showed up and told them I wanted the parts.
After sitting there for a half an hour waiting for them to bring my parts out, they came out and told me they didn’t have the parts because they never ordered them. Again, they would never have told me that because they flat out lied in an attempt to cover up their screwup.
It’s the dishonesty that bothers me…
…followed closely by the wasting of four hours of my time with the back-and-forth of the service center and everything else to happen that day.
Not loving the Rockville Maryland service center…
I never mentioned retrofit. I copied another guys message word for word w the part numbers & 2 days later they sent me the generic “your service is scheduled” then not even 5 mins later sent me the message aboveIf you mentioned the word "retrofit" in your initial message, then that's your issue. You need to clearly state you want these three parts, which are not VIN locked. That's it, any more information and they'll probably say no.
