Installed Torklift’s Eco Hitch
Discussion in 'Model 3' started by nam33r1, Jul 8, 2018.
Tags:
  1. nam33r1
    nam33r1 Member
    Cherry Hill, NJ
    Installed the Eco Hitch on my model 3 this weekend. I can finally carry bikes again! The Hitch went on perfectly. Torklift packaged the hitch very well. I was really impressed with their packaging. The instructions leave a little to be desired but overall they were adequate. I also installed their front license plate holder called the Law.
    • Like x 6
  2. SZNJ
    SZNJ Member
    NJ
    #2 SZNJ, Jul 8, 2018
    Were those pop out pins around the wheel well or the trim around the trunk liner hard to get out?
  3. mekberg
    mekberg Member
    Madison, Wisconsin
    They're quite easy - especially compared to the ones on my prior 2009 bmw X3.
  4. xpitxbullx
    xpitxbullx Member
    Las Vegas
    Welcome to Eco-Hitch family!
  5. Zoomit
    Zoomit Member
    SoCal
    That bike is suffocating without dirt on it!
    • Funny x 3
  6. nam33r1
    nam33r1 Member
    Cherry Hill, NJ
    Very easy to remove. The plastic trunk stops above the rear lights were a pain to remove.they screw on/off and there was some thread lock used so i had to use pliers to take them off being careful not to damage them. I also found that the wheel well lining was missing a pop out pin. 1 on each side! :(
  7. SZNJ
    SZNJ Member
    NJ
    Well so much for the Sep-Nov delivery date! :) Should have my car Thursday. Just ordered my Eco hitch. Thanks for the tips.
  8. SZNJ
    SZNJ Member
    NJ
    I installed my Ecohitch this weekend. Not too bad but rather nerve wracking to pull your new car apart. I think Torklift needs to add some details to the process but in case anyone else is about to install here are a few points.
    1. When you remove the only two tork bolts from behind the rear wheels there is a metal clip that can come off. Keep an eye out for that.
    2. The trunk rest (looks like a 10 sided plastic nut) do unscrew. Mine were so tight I was not sure and the paperwork suggest to pull from the bottom. The youtube video helps here.
    3. The paperwork with my hitch were a little behind as Tesla keeps improving things so hit their youtube channel which has a video closer to what my Model 3 had.
  9. shiz
    shiz Member
    TN
    Does your average road bike look that wide compared to yours on that rack? Trying to get an idea how wide the M3 is.
    Also what is the max towing capacity for that hitch?
    I read of reports of concern for rust where these are bolted on, has that issue been addressed?
  10. xpitxbullx
    xpitxbullx Member
    Las Vegas
    #10 xpitxbullx, Jul 23, 2018
    Model 3 - 72.8 inches in width (6 ft)
    2000 lb tow capacity, 200 lb tongue weight.
    Vinyl washer to place between the hitch and the frame to prevent corrosion. I would have preferred a full pad but this will do.
  11. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    Very clean install.
    Think these are going to be very popular.
    Expect some loss of range due to the additional aerodynamic drag from the bike.
  12. fluxemag
    fluxemag Member
    Portland, OR
    I wonder if the Model X ski rack would work for this, or if the ground clearance is sufficient.
  13. OverJohn
    OverJohn Supporting Member
    CA - California
    What do you think about "The Law" front plate bracket?
