Cigar Man
Intriguing Human
Does Google have an equivalent? I have no problem with using Alexa, but my phone is Android and I use Google Assistant fairly often.
Sort of - Check out AMZN listing for 2020 Avantree CK11 Hands Free Bluetooth 5.0 Car Kits, Loud Speakerphone, Support Siri Google Assistant.Does Google have an equivalent? I have no problem with using Alexa, but my phone is Android and I use Google Assistant fairly often.
I have it under the armrest - I would suggest buying a slim 12v cigarette lighter power adapter do u can plug the usb cable into the power at the armrest - the slim connector allows you to put the tray back -- just have the echo laying right in that tray - plugged into the cig lighter.
Only if the app is open and visible.The alexa app on your cell/phone does the same thing as alexa auto, no?
According the AMZN description of What's In The Box you will receive: Echo Auto, In-Car Power Adapter, Micro-USB cable (1m), 3.5mm auxiliary cable (1m), and Quick Start Guide. The In-Car Power Adapter can be plugged into the Tesla's 12V accessory port, has 2 USB power ports. The Micro-USB cable (1m) can plug into any USB power port or into the In-Car Power Adapter. supplies power to the Echo Auto. You only need to use the 3.5mm auxiliary cable if your vehicle does not support BT streaming.In Canada it is back to $24.99 (from regular $69.99!)
Want to make sure I understand the connection. My M3 has the "old" style 2 USB-A ports in the centre console. Both are full because I have a Taptes wireless charging pad, and then a USB for my sentry and a USB for music (which I do not use that often). How would I connect the Echo Auto? Do I need another adapter or a hub?
The "car cigarette lighter-USB adapter" devices sold everywhere which you would typically use are a tad long and bulky if you want to still utilize the tray under the armrest. I purchased a mini (extra short) lighter adapter and a 90° USB male-female adapter plug on Amazon, and it allows the under-armrest tray to fit perfectly.I'm not sure I get what you mean. Why do you need a slim adaptor? Can you please post a pic of your setup?
Good to know. The In-Car Power Adapter (12V adapter) and USB cable that currently are included in the Echo Auto box appeared to just fit with the tray in place. I will inspect this again in better light.The "car cigarette lighter-USB adapter" devices sold everywhere which you would typically use are a tad long and bulky if you want to still utilize the tray under the armrest. I purchased a mini (extra short) lighter adapter and a 90° USB male-female adapter plug on Amazon, and it allows the under-armrest tray to fit perfectly.
Not into the tray, no, unless you modify the tray. There is a gap in the lip of the arm rest console so the USB cable can pass through, move freely when the armrest is lowered, latched in place. There is space just ahead of the armrest for the Echo Auto, else it can be tucked into one of the cup holders. The 6 microphones on the Echo Auto are arranged in two rows across the top of the unit.The problem I see is that there is no way to route the cable into the tray and still close the lid properly, no?
