Installing Amazon Echo Auto in Model Y.
Discussion in 'Model Y' started by SarasotaGuy, Oct 14, 2020.
  1. jeffbco
    jeffbco Member
    Austin, TX
    No
  2. colea
    colea Member
    Clinton, NY
    Mine had a plastic bracket to attach to a vent but no tape.
  3. Berkshire1
    Berkshire1 Member
    Egremont, MA
    Can someone explain the advantage of using Echo Auto? I just use the Alexa App on my phone which connects to the car just like streaming music.
  4. jcanoe
    jcanoe Active Member
    Maryland
    Well, you're in the right thread so you may want to start reading from page 1.
    In short, with the Echo Auto paired with your phone you can issue voice commands to Alexa including playing music from your phone's music library, listen to Audible books and podcasts. You can even select the channels from the Sirius/XM app if you have an active Sirius/XM subscription. The Echo Auto is always waiting for the Alexa app wake word, typically you set this to be "Alexa", so no need to press a button when issuing a command. The Echo Auto has a sensitive microphone array so that when you speak to Alexa your commands can be recognized over road noise and even most music.
  5. Coloradogramps
    Colorado
    Does linking the Echo Auto to the Y sound system via Bluetooth disable Bluetooth for phone calls? I thought the Tesla only allows one Bluetooth connection at a time?
  6. Berkshire1
    Berkshire1 Member
    Egremont, MA
    Echo App does all of the above
  7. jcanoe
    Maryland
    #87 jcanoe, Mar 2, 2021 at 10:25 AM
    True but unless you are using the Echo Auto device you have to first unlock your phone, press the Alexa app talk button. The value of the Echo Auto is that it is always on, listening while you are driving. There is no need to pick up your phone to access the Alexa app while driving.
    Also, when the Alexa app detects that the Echo Auto is powered on (when you turn on the vehicle) the Alexa app enter Auto Mode. Auto Mode is a simplified Alexa UI for use while driving if you need to interact with Alexa via the phone. When the Alexa Auto Mode is active the Alexa app on your phone behaves like a voice actuated version of Apple CarPlay or Android Auto. The Alexa Auto mode commands include:
    Navigate to "address" for turn by turn voice directions to your destination. Alexa Auto setup lets the user select their preferred map/navigation app (Apple Maps, Google Maps or Waze.) Once you accept and start on a route the phone navigation/map app will display the route.
    Play <audio program>. This is really powerful because Alexa has skills for so many streaming services. The Tesla Model 3 and Model Y lack SiriusXM receivers but if you have a SiriusXM account you can enable the SiriusXM Alexa Skill. Then you can just say "Alexa - play Classic Rock on SiriusXM. Also works for TuneIn, IHeartRadio, Audible, Amazon Music, Spotify, Pandora, and Apple Music. (The only thing that I have found that you can't do is ask Alexa to play music from your iTunes library that is on your phone.) When playing an audio streaming source via the Alexa app the data rate plan on your phone will be used.
    Call <Contact Name> - If you give the Alexa app access to your phone you can place calls using Alexa.
  8. jcanoe
    Maryland
    No. It is confusing until you start using the Echo Auto. Your phone continues to connect to the vehicle over Bluetooth without any change. The Echo Auto has a separate Bluetooth connection with your phone. (If you have an older vehicle that does not support Bluetooth the Echo Auto includes an audio cable to enable the phone to send audio via the cable into your receiver.)
  9. Frog760
    Frog760 Member
    Florida
    I used to have the Echo Auto...moved it to the spouse's ICE car. I have an old echo hockey puck that sits on the rear floor and plugs in just above it. I don't have a Tesla subscription (unless on road trips, $10 is worth it for that). When I get in my car, I set my phone to hot spot and change the Tesla to my hotspot. I can listen to Tesla music and see the same display as with a subscription...but I also can talk to echo to get traffic, weather, location of places (hours, phone numbers, etc), turn on/off lights at home (and HVAC), open/close garage door, update my calendar and shopping lists, and never interrupt my tunes. I tried it both ways and like this way...for my use it's better; YMMV
  10. jcanoe
    Maryland
    The Echo Auto device is similar to an Amazon Echo Dot unit but with only the microphone array and no built in amplifier or speaker. The Echo Auto microphone array has been optimized for being able to hear the Alexa commands in an automobile. Also, the Alexa phone app connects to the Echo Auto via a dedicated Bluetooth connection (a separate BT connection from the one used to stream BT audio and make phone calls in the Tesla.)
    The Alexa app has been enhanced so that when the Alexa phone app detects the Echo Auto device is active the Alexa app switches to Alexa Auto mode (a simplified Alexa UI that is easier to use in your vehicle.) Both the earlier Echo Dot device and Echo Auto device will let you interact with Alexa and control devices inside your home. The Echo Dot was not designed for use in a vehicle (it could become an unguided missile in a collision.)
