Installing factory front license plate bracket
Discussion in 'Model X: Interior & Exterior' started by Merrill, Jul 29, 2018.
  1. Merrill
    Merrill Merrill
    Sonoma, California
    I’m sure this has been discussed before but would like to look at a video on installing the front license plate bracket, I want to do the factory installed bracket and do not mind drilling holes.
  2. Merrill
    Merrill Merrill
    Sonoma, California
    Ok, no answers is there a way to use the factory bracket and use adhesive instead of screws. I want it exactly where the original bracket is installed.
  3. P85_DA
    P85_DA Supporting Member
  4. Merrill
    Merrill Merrill
    Sonoma, California
  5. P85_DA
    I have carbon fiber pieces on my exterior that have held fine with that stuff ..but u need the automotive version ...3m has many different types of double sided ..good luck !
  6. P85_DA
  7. outie
    outie Active Member
    SoCal
    One thing to consider is that the license plate bracket is held by bottom part only with 3 screws. If you use adhesive I am not sure if it’s strong enough without support for the top half of the bracket.
  8. Butka
    Butka Member
  9. Thinkmann
    Thinkmann Member
    Columbus Ohio
    Merrill I removed the nose cone and put it on my wooden workbench face down. On the inside you'll see 3 raised circles that correspond to the mounting holes on the bracket. I used 3 half inch hex washer self-drilling sheet metal screws. I drilled into the center of the center hole from the inside. Flipped it over and attached the bracket. I then drilled the other two from the front and installed the screws. The supplied plate screws were too long for the top holes so I just used the bottom two holes. It's on there good and snug. In the future I may drill the top two holes so I can use the other two screws. Here's the mounting screw I used. Hex head screw.jpg
  10. kfly212
    kfly212 Member
    NY/NJ
    How did it work out after install? any pictures?
    Thanks
