Installing the official Tesla model 3 roof rack
Accentcreate
79
29
France and Australia
Over 12,000 km and no issues. Don't notice a huge hit to range or performance. Makes the car useful.
NeverFollow
1,277
730
625aab43-d101-43ba-9d72-09c79d57c4e5-jpeg.476636
Look great, I also always remove the front wheels. For a long trip, removing the saddles could improve the range.
But I hit the branch of a tree at night in the parking lot of an hotel, and badely damaged the roof of my previous car.
I got the Model 3 roof rack but I will be hesitant to put my bikes above the glass roof.
I am considering putting a tow hitch and a bike holder instead.I would like to find a back rack allowing to remove the front wheel,
thus avoiding to have the bike wider than the car. I saw such bike rack but it must have been discontinued.
If you know such bike rack solution, I would be very interested.
Watts_Up
3,094
2,053
In a galaxy far, far away
I installed the roof rack, but can't seem to turn the key to lock it. Did anyone else run into this issue?
I believe that you need to turn the top bolt in a position where the key can be locked.
The bolt should be in position like on the picture below: :
Note: Be very cautious about the location where you insert the braces below the roof glass.
- The front brace should be almost above the edge of front of the glass.
- The rear brace should be like one inch before the edge of the glass.​
I would recommend to turn the to screw with your hand as hard as you can and then check the roof rack
to see if it doesn't move and if you don't feel any tiny motion on the glass to be certain that each brace is
correctly inserted under the hook and doesn't touch the glass. Otherwise there is a risk to crack the glass.
Then you can use the tool to tighten the bolt. There is a torque recommendation, that you can find in this thread.
But in my case, I just turn the hexagonal tool by holding the small end of the tool, this should be enough.
Holding the tool using the long side allows having more torque but some people tried so hard
that they damaged the hook under the glass or broke the braces.
FrunkLover
37
14
Queens, New York
Hi all - likely moving to a M3 after three years of MS ownership. Wondering if somebody can point me to the dimensions of the OEM M3 rack? Particularly the width. I am trying to see if I'd be able to resize my existing Thule bars to fit the M3, that is if I can get my hand on those little J hooks (big if)...
Thule Aeroblade Edge Flush XL (front) and Thule Aeroblade Edge Flush LG (back) is what I have now, the width is flexible, but may not be flexible enough to resize to the M3.
Any thoughts welcome!
Watts_Up
3,094
2,053
I would recommend using the specially designed braces for the Model 3 and Y.
I you don't want to use the custom Tesla braces, you will have to remove the chrome trim.
See roof rack mounting at 4:20
Model Y E29: Down to the Naked Body-in-White (BIW) - Oil Canning, Roof Racks, More Insulation
Reactions: FrunkLover
tcoombes
1,046
3,060
Northern California
Please let us know your impressions of the pros and cons of the M3 vs. the MS if you make the move.
FrunkLover
37
14
Queens, New York
My proposal is using the J hooks that go under the glass, then attaching my existing Thule bars to the threaded part that sticks up. (With the S with the Pano roof, you pop open the little glass doors and it's one, long threaded piece that attaches to the feet of the bars. The only difference from what I can tell is the threaded piece appears to have a wider diameter and is shorter for the M3.)
Not really optimistic this will work, but figured I'd ask folks who own what the width is to start.
FrunkLover
37
14
Queens, New York
And why not getting the MY instead of the M3, especially when you get used of the practicality of the MS hatchback door.
Cost, range, performance, and availability of the Y in July when my current lease expires. I'm not optimistic Tesla will be able to ramp up production of Ys and get them to the East Coast by then given this pandemic -- but I may be surprised.
I think overall I'd prefer the Y for its space, heat pump for the winter driving I do, and glass roof. But I also am not a fan of the Gemini Wheels, which from what I can tell are the only all-season tires available right now.
Marius A
609
469
NORWAY
I would recommend to turn the to screw with your hand as hard as you can and then check the roof rack​
Do NOT hand crank as hard as you can. Even holding the small end. 5-6nm (recommended pressure in the manual) is nothing.
Drop by any car repair center and ask if you can borrow a torque wrench for 5 minutes.
Or buy a cheap one of you, like me, plan to take them on and off several times.
LytHka
29
132
SC
Jeremy.j.hall
15
9
Uk
It used to be 5-6Nm, guess they figured out that was a problem or they've modified the construction
Interesting - I bought my M3 rack less then a month ago and the book states 5-6Nm - This feels like a bit too much, and the bolts are almost completely through the wingnuts by this toque - meaning the allen key stared slipping - I think I'll downgrade to 3Nm!
Feels sturdy.
Does anyone else get a worrying noise when tightening the bolts? Glass is fine, but there is some clicking / creaking which has me constantly checking for cracks... Must relax!
