Instrument panel does not turn on, unable to drive
Discussion in 'Model S: User Interface' started by dlt, May 18, 2014.
  1. dlt
    dlt Member
    Finland
    I experienced a strange issue, which started yesterday when I parked my car for a while. After returning to car, the smaller display did not turn on, and the system gave 6-8 different error messages (abs, traction control, airbag, regen, parking brake failure etc). After countless reboots instrument panel turned on and I was able to drive it back home (but with all mentioned systems disabled). After stopping and shutting down all errors disappeared and the car worked normally for the rest of the day.
    Today, the problem came back, but this time nothing helps. I have been trying to reboot both screens, turn power off, locking the car, opening and closing door, depressing brake pedals etc in many different sequences without any help. Instrument panel stays dark and the error messages are displayed on the main screen.
    Any ideas? Is there a way to do a hard reboot which would reboot all systems? This is an european model (vin 29205). I guess it may be related to the service campaign which will require the instrument panel to be replaced.
  2. andrewket
    andrewket Well-Known Member
    I have no suggestions for you other than to say if it was me the car would be going in for service and I would not rely on the car. It sounds bad.
  3. NoMoGas
    NoMoGas Supporting Member
    Los Angeles, California, United States
    I'd call Ownership ASAP and would not drive the car another foot. Please let us know how this resolves.
  4. Alysashley79
    Alysashley79 Active Member
    Seattle(ish) WA
    I'd also call ownership. But in short yes you can pop the frunk pull the plastic piece on top of th fuse. Box and pull the fuse (just the one fuse) ownership can help walk you through the correct one. I ow which one on my car because I've had to do it one time as a master reboot. You pull it out with a pair of needle nose pliers and let it sit out for two minutes and then put it back in. If that doesn't solve the problem then you'll likely have to have it towed to service.
  5. RiverBrick
    RiverBrick Active Member
    Mount Washington Valley
    Agreed that service has to be called. It's unfortunate this has happened to the OP, because there doesn't yet appear to be a service center anywhere close to Finland.
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    The risk of bringing a Tesla into a country where it is not officially supported...
  7. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Call Tesla. They can remotely diagnose it. It might be something as simple as a low 12V accessory battery, which you could trickle charge yourself.
  8. dlt
    dlt Member
    Finland
    Ranger came and fixed it today. It was caused by some problem with Instrument panel, which was replaced and now it is working again.
  9. Kraken
    Kraken Member
    Voltageville, CA
    yet Tesla comes through strong.
  10. dsmith2189
    dsmith2189 Active Member
    I'm just wondering why you couldn't drive it. the screens are independent of the driving system. I have driven while rebooting them (What can I say, the light changed sooner than I expected.:redface:)
