The noise is coming from that hideous insulation you put on the pano roof Hey, what ever floats your boat but I just don't get the need for it. My S heats up so quickly and stays warm. Now I could use some better floor heat but, that's a Tesla weakness I live with.
I have an August 2016 Model S, and the sun screens work. They may not fit perfectly, but they fit well enough.
Do you mean to stay this stays on the top w/o glue/ tape/ suction cups if you can get the perfect measurement?
If I was going to do this, I would: 1. Remove the sun screens (if you have them). 2. Add a couple of semi-stiff plastic strips (or other semi-rigid material) to the foam that are just longer than the foam (which you've cut to the exact size). 3. Put the strips into the grooves that the sun screens used. This will hold the foam in place without tape or glue. 4. Store the sun screens in a safe place for installation next summer.
I feel temperature measurement is more sensitive to leakage of outside air than the sound meter. I feel glass transmits heat and sound more than the panelled body. Placing the acoustic pyramid studio foam on the roof and on the side glasses should reduce the heat loss and the noise transmission to some extent.
How cold does it have to be in order to have to consider insulating the windows where you're at? Drove over Vail pass a month or so ago with snow conditions, and then up to Salt Lake City in UT during some blizzard where you couldn't see the road nor markings - just turned on the seat heater and played with the internal temperatures. I'm up in the Lake Tahoe and we had snow as recent as this weekend, but it rarely gets down to single digits (and we burn oak). Of course I'm the type who rides a motorcycle with heated gear. Maybe heated gear is an option?
Depends on how sensitive you are to cold and how long you're going to be in the car. Probably 0C for long duration and -10C for short duration (assumes you are preheating).
1/4" fan fold sheathing vapor barrier works great. I had this on hand for my house and remembered last winter having to wear my hood or hat in the car. Starting cold, at -30 F it never would warm up to the set point on my two hour commute. With this insulated glass ceiling and the heated seats, I'm warm and passengers haven't noticed until I asked them . My head used to get cold and I'd leave the temp at 69 F. Now my bald head stays bare and I prefer the temp set to 67 F. I recommend it for winter. I haven't tried -30F with it, but am eager to.
I know I'm resurrecting this thread from a long way back, but I've had similar issues in my 2016.5 Model S w/panoramic sunroof. I've had the same issues with my head getting cold when the temperatures in Colorado dip down below 35 F or so. The car interior itself was warm, it just always feels like there is a slight cold breeze coming down from the pano roof area. I figure it's just air getting cooled against the glass, then descending (denser) onto my head. I'm fairly tall, and I have a very close-cut haircut, so that seems to exacerbate things. There's definitely no actual air leaking through, so I'm going to try one of these foam insulation tricks. Also, I'm hoping it has the secondary effect of stopping the last little bit of sunroof ticking/clicking noise coming from that area. The SC has managed to eliminate...85% of it, maybe this will muffle that last 15%.
I used this: 7 layers. Often used for mobile homes. You can buy them in big sheets. Cut them to size, had them trimmed (tape was included). Te side windows don't need fixing. Roof and trunk get held by the sun screens. Front window fixes with suction cups (also included). The insulation effect is defenitely there. Noise wise I doubt very much if it will stop the ticking. But the insulation is quite sound deadening which produces an intimate atmosfere.
