Integration with Google Home / Google Assistant - Now available for general use
Discussion in 'Model S: User Interface' started by Gol4, Jun 7, 2017.
  1. Pagemakers
    Pagemakers Member
    Manchester UK
    But if it can’t contact the car wouldn’t even asking it to flash the lights fail?
  2. RTPEV
    RTPEV Member
    Durham, NC
    The point is that the "flash the lights" command will likely fail if your car is asleep, but it will start by trying to wake the car up.
    That way, by the time you issue your second command (the one you really want to do), the car will be awake and responsive.
    And if the car happens to be awake, or wake up quickly, then the flash the lights command is relatively harmless.
    The point is you want the first command to be something that actually makes the car do something, rather than just retrieve status.
    I tried changing my Google routine from:
    "How far can I drive"
    "Turn on climate"
    (which failed for me, even when I put in a significant delay (count to 100) in between those two commands)
    to:
    "Flash my lights"
    "Turn on climate"
    (with no delay in between)
    and it worked great! Give it a try!
  3. Pagemakers
    Pagemakers Member
    Manchester UK
    Ah. Understood.
  4. Gol4
    Gol4 Member
    San Jose, CA
    Thanks to @RTPEV for patiently helping triage the issue. The 3 does seem to go into a deeper sleep state and takes longer to wake up. The S and X have an always-connected option which is not there in a 3. Based on our testing, it seems like it takes about 7 seconds to wake up a Model 3. Unfortunately Google has a 5 second timeout which cannot be changed. So in all likelihood the action would fail the first time you try it and the car was asleep.
    This situation was made worse by a bug in EV Car that was not calling wake_ip every time. It was not being called for commands that just return status. That issue has been fixed now so your interaction with EV car fails the first time around, it should work in the second iteration. Let me know if that doesn't happen.
    As per @RTPEV suggestion, I am also considering adding a new command that does nothing but wake up. You could use it seamlessly in a routine. That will involves changing the voice model and going through the approval cycle with Google so will take some time.
  5. sdmack
    sdmack Member
    St George, UT
    Hi Gol4,
    Just letting you know that your latest change also improved connection to my new 2020 Model S, with software 2020.8.1
    Prior to your latest change, Google Assistant would never connect to the car unless I first connect to the car with the Tesla app. Multiple subsequent attempts to connect would also fail.
    Now, the first attempt by Google Assistant fails, but the 2nd is successful. Note that this car does not have the always-connected option, similar as M3, so I suspect it also needs 2 attempts to get around the 7 second wakeup latency.
    BTW awesome work on the feature, thank you
  6. HammerNow
    HammerNow Member
    Sweden
    Will it work with 2 Teslas? or will it then only work for one of them?
  7. Gol4
    Gol4 Member
    San Jose, CA
    Works with multiple cars. Just say "switch cars" to switch between them.
  8. Taurec42
    Taurec42 New Member
    Germany
    Hello,
    What would it takes to helo to bring the App to Tesla Owners outside the US?
    If it is only a Language problem i can help. I already worked with others Developers in translating their Apps. Either with simple Word Files. XML Files or directly with GIT.
    I am sure other Useres would also love to use Talk to EV.
    Regards
    Lars
  9. destructure00
    destructure00 Active Member
    Scottsdale, AZ
    Just thought I'd drop in here and show EV Car working with the Hansshow power frunk kit I installed on my Model 3 this morning. Love it!
  10. MasterT
    MasterT Member
    Home
    I've been getting lately "Can't reach Google at this moment" error - unlinking/relinking EV Car helps for one or two commands but then the error returns. Anyone else getting this?
  11. Gol4
    Gol4 Member
    San Jose, CA
    Its been working fine for me. If it can't reach Google at all it could be a network or Google issue. Do other Home Assistant commands work fine when you see this issue?
  12. MasterT
    MasterT Member
    Home
    Other assistant commands work ok. The error "cant reach Google at the moment" comes up after EV Car is summoned and I try to speak EV Car command - I can type EV car commands and it executes them ok. I've tried unlinking and relinking multiple times to no avail.
  13. nivS1978
    nivS1978 New Member
    Denmark
  14. Gol4
    Gol4 Member
    San Jose, CA
    I just tried this and work fine for sending to a Google Home and Phones on account.
  15. Gol4
    Gol4 Member
    San Jose, CA
    ... and the Google Home did start the action. For good measure I did Unlink and try also.
  16. swoosh82
    swoosh82 Member
    This service seems to be taken down as of today....6/27/2020. :-(
  17. mhcrowder
    mhcrowder Member
    North Carolina
  18. MasterT
    MasterT Member
    Home
    Hopefully it's a temporary glitch ...
  19. Gol4
    Gol4 Member
    San Jose, CA
    "takedown" because a privacy link was invalid. :rolleyes:
    I guess it'll have to go though the whole approval cycle again before it is restored.
  20. MasterT
    MasterT Member
    Home
    Please let us know if there is anywhow we can help
