Can I just ask, was your car at home or away and plugged in or not for this? Just trying to understand what is working / not working with IO right now as I’ll likely end up on this tariff when my current GO deal expires at the end of next month. CheersForgot I hadn't turned my IO off in the app! Teslamate shows the constant waking up very nicely!
At home, not plugged in. It works fine, if you don't want a circa 1% drain per 12 hours just toggle the smart charging on/off when needed in the app.Can I just ask, was your car at home or away and plugged in or not for this? Just trying to understand what is working / not working with IO right now as I’ll likely end up on this tariff when my current GO deal expires at the end of next month. Cheers
Nope. IO set to 95%, car to 90%, charges to 90%Anyone else noticed that charges are about 3% lower than should be? Having 90% selected it charges to 87 and having 100 selected charges to 97/98. I have 100 set in the car.
You’re doing it the opposite way to me by making the car stop it as opposed to IO. Maybe that’s the way to do it.Nope. IO set to 95%, car to 90%, charges to 90%
All very well until you want 100% which will still then only give in my case 97/98Just set IO to 100% and control in the Tesla app. That way you always get what you need. Plus you may get some earlier charging slots as a bonus.
Thanks Drew, good to know@ItsBlacknWhite Yes (& we occasionally charge the Tesla via IO & the other EV on a granny charger from 11.30 at the same time).
I’ve decided to switch the smart charging off every morning and back on every evening just as I’m plugging in. I don’t really like the octopus intelligent app unnecessarily draining energy from the vehicle (which will of course increase the cost of charging, which makes no sense)Some feedback from octopus re phantom drain with intelligent octopus
The Intelligent Octopus application polls the vehicle once every hour, which could be the reason for the phantom drain in this case.
It is possible to switch off the smart charging function periodically to work around this in the short term, so hopefully this helps to prevent any further issues.
Go to profile, Intelligent Octopus, and the Disconnect vehicle option. Likely need to go through connecting it again after credential change. Either that or the app may prompt for new credentials once it realises authentication is denied. I imagine that will happen ordinarily when the access token expires.
