Yes, they evidently forgot to enter in the kW size of the system, so the figure is off by about 9.5 times. As arnolddeleon can tell you, it is important that PG&E have the correct size, since they may refuse to credit you with power fed back to the grid above the amount they think you should be able to generate. I suppose the tricky point here is that you already had a 3.2kW system. I'm not sure how you get both systems entered into the PG&E system, but I think you need to be sure that they know the total is 12.7kW. If you retained NEM1 on the original system, perhaps the accounting would be done separately.
