Interesting driving stats thread
Discussion in 'Australia' started by Vostok, Dec 18, 2020.
  1. doctorwho
    doctorwho Active Member
    Eurobin, Victoria. Australia
    199,771km so far in my 2015 S85. Average energy consumption of 187Wh/km
  2. Flatbat
    Flatbat Member
    Melbourne
    #22 Flatbat, Feb 21, 2021
    My 2020 model 3-LR has 18" tyres @ 42psi cold. Wheel covers off. It has used a run of the mill 176 Wh/km in the 14 months since new.
    This equates to just 426 km range on a full charge. It is an average of course, but it is a long way below the guessometer's 498km. I tend to drive in spritely fashion and have the TACC set to speed limit +4%. Last week I needed to do a return journey of ~420km with the car parked for two days in the middle, without the possibility of charging anywhere. This gave rise to some range anxiety.
    So I thought I would temporarily modify my driving habits to see how the range improved. Plan was to drive at speed limit minus 2kmh for 100kmh zones and at posted speed limit for lower limits like 80kmh. Chill Mode to encourage smoothness and do not overtake anybody. Leave Aircon off, unless it becomes uncomfortable, no heating. Do not use sentry mode while parked for two days as it uses ~6% a day. So by no means being a hyper-miler, just drive sensibly and don't be in hurry.
    When I departed the car said it would arrive at the midpoint with 50% charge. I actually arrived there with 60% charge consuming 28kWh and 131Wh/km. A good start to my plan.
    After the two day sit, the battery had lost 2%. On the return journey it was warmer and because I was not at 100%SOC regen was available the whole drive. I achieved 117Wh/km.
    Out and back average was 126Wh/km.
    Ended up getting home with the battery at 22% SOC and the guessometer saying 102km left! Had I kept driving at the 117Wh/km I was using on this drive, it would have done another 140 km (in theory). So 423+140 a total of 563km vs the 426km range I have achieved over the cars life! I knew driving more conservatively would improve things, but I was really surprised by how much.
    Here are two drives over the return half of the journey above, completed several weeks apart using the different driving methods.
    Average speed was the same on both days. Although one was colder and I would have been using the heater. One trip used 36% SOC whereas the other 51% SOC. A 30% difference in efficiency or thereabouts.
    It is all very interesting, but I think I will revert to my old driving habits now.
    • Informative x 8
    • Helpful x 2
  3. louco73
    louco73 Member
    Gold Coast
    @Flatbat not sure you want to show that maximum speed on a public forum? :)
    Fantastic information!
    Has anyone actually graphed out what the real world consumption is for the different Tesla cars at say 90, 100 and 110 km/h? I don't use any of the data services, but I suspect they could provide that information by analyzing their fleet?
  4. Flatbat
    Flatbat Member
    Melbourne
    Yes it would be good to see some speed vs consumption graphs. There is an old one floating about from A Better Route Planner but it didn't take into account the option codes for the cars. Also back then the 3 LR was single motor whereas its a dual motor now. So many variables.
  5. Vostok
    Vostok Active Member
    Sydney
    176 Wh/km is somewhat on the high side... I have the same car as you and my lifetime average is 156 Wh/km without paying any particular attention to trying to drive efficiently. Aeros on, tyres typically pumped up to mid-40s.
    Without AC on and always driving to the speed limit, I get under 130. But 117 is very good, I don’t think I’ve ever got under 120 for a drive of any length.
    If you ever need to get over 500 km range in a Model 3 LR I don’t think it is particuarly difficult to do.
    And Sentry is a power hog.
  6. captBill
    captBill New Member
    Swedesboro, NJ
    I used a standard formula for power needed
    HP=(W×R×V)/365+(A×.00256×Cd*xV^3)/375)/.95
    It can be converted to the metric system. This is for SAE horsepower. It can be plotted in 5 km increments. it shows that the power needs to go form say 50 mph to 60 mph is 50% more. Than to go to 70 mph takes an other 50%. For model 3 and model Y Cd = .23.
  7. captBill
    captBill New Member
    Swedesboro, NJ
    R = rolling resistance = .01 @3.5 bars 51 psi, .011 @2.9 bars 42 psi tire pressure for model 3
  8. ganzo
    ganzo New Member
    Venice, CA
  9. MikeHolliday
    MikeHolliday Member
    Worthington, Ohio
    You admit that you drive in a lively fashion. What do you expect your range to be when you drive in that fashion. I have a Model Y and when I drive locally I also drive in a "Lively" fashion. I like to accelerate to speed limit between red lights as much as possible and yes that effects my range greatly, but I do not give a rats whoo-hoo. But when I have taken 1,200 mile (1,920 kilometer) trips this winter I keep my speed within 5 mph of the speed limit and I can easily go 200 miles (320 kilometers) and use 71% of the battery. That is running at US Highways speeds 70 mph (112.6 km/h) , Climate Control set to Automatic with the Temperature set to 71 degrees Fahrenheit (21.7 degrees Celsius) and on autopilot. If I drive 10, 15, 20, etc. mph over the speed they will not get anywhere need the rated mpg or L/Kilometer...
  10. TFKarl
    TFKarl Member
    Moscow, Idaho
    Thank you for the data. I also have a 2020 M3LR with 18” tires and have anecdotally noticed the difference in power usage when allowing myself to have moments of swift acceleration versus more patient driving, but love that your numbers show how much of a difference driving styles, as well as other electronic usage in the vehicle, makes.
    It really increases my range confidence knowing that I can make similar adjustments in order to make it to a charging station on my rural Northern Idaho roads.
  11. Rudolf
    Rudolf Model 3 Long Range Dual Motor
    Switzerland
    #31 Rudolf, Feb 22, 2021
    That's teslafi.com
    No phone app available, as far as I know, but it displays reasonably well in the mobile Chrome browser on my Android phone in landscape format.
    See also this thread on this forum
    TeslaFi or Not? That is the Question
  12. asummer
    asummer Member
    Vancouver
    my M3 SR+ is just over 1 year old
    i reset trip A monthly
    best month: 130Wh/km
    worst month: 180Wh/km
    (winter in Vancouver, BC is fairly mild, i can't imagine how high the consumption number would be in places with -20c)
    i never reset trip B
    whole year: 150Wh/km
    last week i checked, the tire pressure were 40 to 41psi
  13. Futuresystem
    Futuresystem Member
    Brisbane, Australia
    Yes- it IS all about driving style. So many people are quick to blame the car when in fact it’s their right foot that is the key.
    (And yes, I know rain, temp, terrain, headwind etc have a big effect too.)
    My lifetime use in my “stealthy P” is around 156 Wh/km (249 Wh/mile).
    Never forget that aerodynamic drag is the SQUARE of your speed. That also means that a 10k headwind is much more draining than the saving you will get from a similar tailwind. Likewise- driving that little bit faster makes a big difference, as of course does quick acceleration.
    The good news is that slowing down will help a LOT when you’re tight for range. Don’t do it just for the last little bit- use the screen prediction to see how you’re going and slow down early which makes a huge difference.
    cya!
  14. bluestreak
    bluestreak Member
    Melbourne, Victoria
    You guys with newer cars should be grateful for the phenomenal range you get. I have a 2015 P85D and driving at my most conservative in ideal conditions can never see under 190 wH/km so my range is around 340 km actual. I would be over the moon to see 150, let alone 120. Newer cars have improved out of sight.
  15. Vostok
    Sydney
    Oh, I’m grateful all right! It’s brilliant.
  16. Gquinn
    Gquinn New Member
    Brisbane
    <200 for a MS is good. These other guys a re talking about M3s I believe. My MS average was 200. My MX ids more like 250/km.
  17. Candleflame
    Candleflame Active Member
    QLD, Australia
    with an average speed in the 70s you sort of expect that.
  18. Flatbat
    Flatbat Member
    Melbourne
    Not really. As shown, with two trips over the same route, both with identical average speeds in the70s the Wh/km varied from 117 to 159. Most people would not expect 159 Wh/km with avg in the 70s. It is more about the range of speeds used and driving style.
  19. Candleflame
    QLD, Australia
    i have done multiple trips through the outback with aircon at full blast with 45C outside. Usually driving 80-85km/h so i stay below AC charging speed (bout 11.8kw/hr)
    Really.
  20. ittah
    ittah Member
    Melbourne
    Here is another angle, the effect of temperature, which makes sense when you consider creating heat and extreme cooling.
    (Model 3 Stealth, Non Heat Pump)
    32000k 148 Wh/Km average.
    • Informative x 2
