It was posted Oct 20, 2017.
Help us understand how it is outdated & inaccurate. It is disingenuous to simply say it is.
I watched the rest of the video and it does get better than my initial impression. However:
1. Incorrect the pack heater turns off with range mode on. Thresholds changed, not off. Will still turn on at a certain temp.
2. Incorrect that cabin heater will draw 6kW with range mode on. His mistake was going to "hi" mode, which effectively cancels range mode and blasts the heater. Anything less than hi, you will have reduced heat capacity. Of course, if it's cold enough you may be tempted to use hi anyway, which more than negates the savings from range mode, as using a thermostat would be more efficient that blasting the heat when you get too cold, then turning it back down when you're too hot.
3. Incorrect about 1-2kW heat from drivetrain while driving. Of course the real answer is it's much more complicated - referring back to his own video on rapidly heating the pack (much faster than the pack heater) by using heavy throttle and regen. But take a hint from max battery mode, with highway cruising the pack heats much faster with driving than manually with the pack heater.
4. Wrong about front/rear split vs speed, This has changed wildly between firmwares, but you can clearly hear the front motor with range mode off on some firmwares at low speeds. I stopped doing a personal QA cycle on the car everytime a new firmware is released, so can't say the exact parameters of it now. This spreads my anger over what Tesla has broken in a given release out over time.
5. More opinion on this one, but he recommends keep range mode off for long trips and on for long trips. I would say if anything, it's the other way around. Warming the pack, now days, is the real consumption benefit of range mode - lower internal resistance and more available capacity, which due to the incompetence of Tesla's trip meter is unlikely to be visible to you on the dash, but you will get more miles out of the car assuming you drive long enough.
