Did another comparison between range mode and non range mode, with climate control off, Almost entirely highway travel, one ludicrous merge, aiming for about 78mph, and I control for road differences by using evtripplanner fed with my actual trip time. 0 mph wind.
Start: range mode off, 45 psi starting, 49 psi ending, 343Wh/mi, evtripplanner estimate 382Wh/mi
Return: range mode on, 48 psi starting, 50 psi ending, 323Wh/mi, evtripplanner estimate 364Wh/mi
So range mode only got 1.2% better this time, but you'll notice that tire pressure was significantly higher when range mode was on, which probably alone accounts for 1.2%.
I should add, that at low speeds with range mode on you can still quite clearly hear the front motor under more torque.
