davidc18
Everyone should read the fine print you sign when you pick up your Tesla. It is also available in the car in the owner's manual. It is a must read IMO.
The second is a state-of-the-art driver attention system powered by facial recognition software, which uses infrared lights to track head position to monitor driver’s attentiveness. Super Cruise is unlike any other driver assistance system.
Proprietary head tracking software helps makes sure your eyes are on the road, and if not, visual alerts signal you to grab the wheel, followed by seat vibrations, if needed. If driver does not respond, hazard lights are activated before the vehicle comes to a controlled stop.
Looks like GM is another company that thinks you need to have added facial input (albeit by infrared lights in their case).
GM Supercruise CT6 Sedan with Super Cruise | Cadillac
The Tesla camera would likely be infrared too if it is going to be used as part of the AP system otherwise it will be very difficult for it to work properly at night.
All they need to do is leave off the infrared filter. CMOS is infrared sensitive.
Its unlikely GM uses infrared "lights". The reporter simply doesn't understand the technology. Humans emit infrared.
Until they require it for AP functionality...Just tape something over it and quit worrying.
hope not ... my eyes do tend to glaze over while my wife is speaking at me ......possibly monitoring the drivers head position and gaze to assure attentiveness when using autopilot?
Why is this in an “affordable” car?
Additional explanation and details on its usage in the Lexus.This is not new technology. My 2008 Lexus LS600hL had an IR camera mounted just above the steering wheel facing the driver as part of their pre-collision driver monitoring system.
Lexus engineers have also developed an Advanced Pre-Collision System (APCS). It is the world’s first system designed to help detect pedestrians in the vehicle’s path. APCS, with two small cameras mounted at the front of the car that work in conjunction with millimeter-wave radar, is sensitive enough to detect certain nonmetallic objects.
As part of APCS the LS also offers the world’s first Driver Monitor System. A third camera, mounted on the steering column, monitors the orientation of the driver’s face. If the camera detects that it appears the driver is not looking directly ahead for a few seconds or more, and if an obstacle is detected ahead, then it alerts the driver first with a warning chime and a flashing light. As the car gets closer to the obstacle, APCS can begin to gently apply the brakes on its own. To assist the driver in maneuvering around the obstacle, the system reprograms the steering ratio, amplifying the intensity and quickness of the steering response.
While all of this is happening, the system automatically retracts the front seatbelts and prepares the brake system to respond with full force when activated by the driver in anticipation of a possible impact.
If you don't care about AP, like me, then it won't be an issue. If you're all about AP, you're SOL.Until they require it for AP functionality...
