Interior lighting from Premium Package
Discussion in 'Model S: Interior & Exterior' started by smilepak, Jul 12, 2015.
  1. smilepak
    smilepak Active Member
    Eastvale, CA
    Can someone with recent purchase who got the premium package that came with power lift gate and interior accent lights check something,
    i li know at night, I do see the lights under by the arm rest on the door. While driving yesterday night, i didnt see any in the driver and passenger foot area. Was there suppose to be one? If so should it be on while drive or only in park mode?
    where else should the light be?
  2. MsElectric
    MsElectric Active Member
    New York
    Good question. I'd like to know too. I see the lights under the arm rests on the door but I could not see any foot well illumination and i thought that was surprising, especially for a very pricy options package. I'm still surprised you can't change the color of the ambient lighting to a color like amber that is more night vision friendly. The S Class has a nice interface for adjusting the color of the night vision lighting and that's offered as a standard feature.
  3. smilepak
    Eastvale, CA
    The S class illumination is slick!
    I am still trying to figure out if I got a defect light package or not, given when I picked up the vehicle a few days ago, the airbag contact was not even connected. How did that pass QA was beyond me.
  4. Max*
    Max* Charging
    NoVa
    I don't have it under the drivers or passengers footwell (while driving. While parking it lights up), but I do have it BEHIND the drivers and passengers seat footwells for the 2nd row passengers.
  5. Tony Lin
    Tony Lin Member
    Hong Kong
    the front foot area lights up when the door is open, while in drive, they are off.
    the passenger foot area, I didn't check :rolleyes:
    premium lighting intensity is set according to your 17" display setting!
  6. Max*
    Max* Charging
    NoVa
    I never knew that.
  7. smilepak
    Eastvale, CA
    Good to know. Interesting they didn't keep the footwell area light on while driving. They keep all other accent lights active.
    Would've been nice to have it kept on.
  8. LLWS
    LLWS Member
    Woodbridge, VA
    Agreed. Something new to play with on the car tonight.
  9. mknox
    mknox Well-Known Member
    Toronto, ON
    Me too, but again, only when parked or you first open the door. They go out when driving just like the front footwell lighting.
  10. Tony Lin
    Tony Lin Member
    Hong Kong
    I agree!
  11. kuttakamina
    kuttakamina Member
    DC
    Its configurable I think? I'll check later today to make sure.
  12. mknox
    Toronto, ON
    No. You can only select whether you want the ambient lighting on or off, and it only affects the door panel lights.
    My last car had ambient footwell lighting that would brighten up wen a door was opened and dim way down when driving. I liked that.
  13. Max*
    Max* Charging
    NoVa
    The only thing you can configure is the brightness. The footwell lighting being on/off is not configurable
  14. Tony Lin
    Tony Lin Member
    Hong Kong
    Hopefully it can be adjusted with new software update.
  15. tliving
    tliving Member
    New England, USA
    The rear footwell is lit with the premium lighting. I love the lighting, it wasn't worth the $1K I paid for it but I knew that when I did it and don't regret it (so maybe it was worth it??)
  16. rickgt
    rickgt Enthusiast owner/member
    Carmel
    yes, this is my experience as well...
  17. duyph4m
    duyph4m Member
    Oslo Norway
    Can somebody post up some Pictures please :)
  18. joywalker
    joywalker Member
    Hong Kong
    The driver and passenger foot lights definitely turn on when parked. I saw it tonight.
    Not sure about the back seats.
  19. Ingineer
    Ingineer Electrical Engineer
    So I'm trying to understand the accent lighting, like under the door. At night does this illuminate continuously? What else stays lit? My non-premium lighting car has the front footwell lights (however dim), one in the Frunk, and one on the Hatch for the trunk. There are cutouts and wiring for 2 extra trunk lights, but no LEDs. Each door has a Red rear-facing light and a ground facing white "puddle" light, but no LEDs in the pop-out handles.
    The footwell lights turn on when the door is opened, but don't stay on long. The 4 front/rear "map" lights stay lit longer. I'm not sure what the rationale for this is.
    I definitely don't have the rear under-seat floor lights. Do these also stay lit at night in the premium cars?
    I also don't have any settings on the MCU (Center Display) that pertain to this. I'd love to figure out how this is enabled, since all the wiring is there and it's only logic. Same with the fog lights, cornering lights, etc.
    Near as I can tell so far there are 2 extra sub harnesses that are put in for 2 options, one is the premium audio. It gets a harness that adds in a green connector to the MCU (line outputs) and runs the the extra amplifier module under the steering wheel. My car doesn't have that and the green connector on the MCU is empty.
    On the cars with the rear liftgate power option, there is a sub-harness and several modules. The main power/control input for the controller module in the passenger side trunk area is present, but the rest is not there.
  20. smilepak
    Eastvale, CA
    Under the door arm rest both driver and passenger side stay lit while driving. The front footwell only light up on entry. It turns off while driving. A bit dim and cheesy.
    The whole package, only lift gate is worth while. Rest was cheesy. Like turn lights and two dinky ambient lights. Fog light is cool, but no really used. Waste battery power at night
