My audio system has a problem whereby the audio sound shifts to the front passenger speaker only. Any ideas or suggestions on solutions?
Mine has shifted to the back a few times... I usually find this after a software update. I have changed the settings and gone about my business. It is not Nav because the slider in the adjustment menu changes along with all audio.
I have found various audio sources seem to require manual adjustment of the front/rear fader for some reason. One source will sound like it's coming out of the windshield, so I bump it to the rear a bit, then another source will be skewed way too far to the rear.
Its the NAV. Thats all that would do that. and it does work that way. It may be an error, but thats where the problem is.
I have the same issue (it is only with slacker and USB - I have found if dolby is off it is less dramatic). Ranger coming out to fix other issues - will have them look into that too.
