Vendor Introducing Avant Garde Wheels A.R.T. M600-Series
GetYourWheels
Global Vendor
The A.R.T process impacts the micro structure of aluminum by utilizing three hydraulic rollers to apply pressure to form the inner rim area.
The rollers move down the barrel applying pressure to compress, stretch, and form the entire wheel barrel producing optimal weight savings while improving material strength.
This process actually alters the grain of the aluminum to produce a wheel barrel that is significantly lighter with enhanced strength comparable to fully forged wheels.
A.R.T helps reduce the weight up to 25% when compared to a standard cast wheel through this finer and more even aluminum structure.
M610 weights for 19” sizes start at 21 lbs/wheel while weights for 20” sizes start at 22 lbs/wheel.
Wheel Models: M610, M615, M621, M652
Bolt Patterns: 5x112, 5x114.3, 5x120, custom 5-lug available
Offset: Custom offset available
Finish Option:
- Bespoke Level 1: Single stage powdercoat
- Bespoke Level 2: Paint match
- Bespoke Level 3: Hand applied (Brushed, Polished, etc…)
M610 Sizes Available: 19x8.5 | 19x9.5 | 19x10 |19x11 | 20x9 | 20x10 | 20x11 | 20x12
M615 Sizes Available: 19x8.5 | 19x9.5 | 20x8.5 | 20x10 | 22x9 | 22x10 | 22x10.5 | 22x11
M621 Sizes Available: 19x8.5 | 19x9.5 | 19x11 | 20x9 | 20x10 | 20x10.5 | 20x11 | 20x12
M652 Sizes Available: 19x8.5 | 19x9.5 | 20x8.5 | 20x10
Here is a set of AG M621s with A.R.T. Technology we did for our customer's Model S in 20x9/10.5 in Gloss Bronze Burst wrapped with 245/275 Continental DWS06 tires!
The color combo looks great and unique against white, a drop is next on the list and it should look perfect after!
Introducing the new Avant Garde Wheels M632 rotary forged using AG's ART technology
M632 - Rotary Forged - Avant Garde Wheels
Available in:
19x8.5 / 9.5 (Custom Bolt Pattern/offset/finish)
20x9 / 10 / 10.5 / 11 (Custom Bolt Pattern/offset/finish)
5x112 Audi and Mercedes fitments in Machined SIlver
New Mustang Fitment:
5x114.3 20x10 +30/11 +52 Gloss Black / Machined Silver
Heres a set of M632 in 20x9/11 in Polished Liquid Bronze installed on a Mercedes CLS
These are in stock and ready to ship in standard fitments/finishes!
Contact [email protected] with any questions or interest!
I have nothing but great things to say about Jason and his knowledge on the perfect fitment for Teslas.
The set of M621's Jason helped me with are great and am very happy with them. My car is on coil suspension and here is a picture after the drop
Reactions: DA808EV
Thanks for the kind words! Love how your M621 setup came out especially after the drop!
Heres one more shot after the suspension:
Reactions: DA808EV
These look great.
However do they still carry the range penalty that the stock 22s impose? Or do their drastically lighter weight make a difference?
These 22" M615s will weigh around 32/34lbs in the 22x9/10.5 combo, so they're pretty light for 22"s
I'm not actually sure how much the OEM 22"s are but I'm guessing much heavier considering the OEM 21"s are ~35lbs.
So these should help reduce the range penalty you get from upgrading to 22"s!
Setting up one of our customer's Nissan 350Z with Avant Garde's new M610 that replaced their old M310. The M610 is the new rotary forged version available in many new sizes!
19"
19x8.5
19x9.5
19x10
19x11
20"
20x9
20x9.5
20x10
20x11
20x12
Check out that fitment! Once lowered, should be PERFECT!
AG Wheels just released some new sizes for their rotary forged M600 series wheels.
The M610, M615, and M632 are now available in a 20x9.5 deep concave!
Perfect to fit wider Deep Concave fronts, or less aggressive 20x9.5 square setups for Audis!
Featured in the photos below is a set of Copper M632 in 20x9.5/11 Deep Concave all around,
Also featured are set of Vredestein Ultrac Vorti tires in hard to find 235/35/20 265/30/20 sizes.
Made in the Netherlands, Vredestein offers many uncommon and hard to find tire sizes, great performance, quiet rides as well as a gorgeous european design.
GetYourWheels now offers the full line of Vredestein tires, so contact us for a quote!
Vredestein banden
