iOS 11 and the Media Player
Discussion in 'Model S' started by navinsiri, Sep 24, 2017.
Tags:
  1. navinsiri
    navinsiri Member
    Central NJ
    Since I've updated my iPhone 7 to iOS 11 it hasn't been showing the song information (name, album, artist) on either of the car displays. Wondering if anyone else is having this issue? Is it a bug from Apple's side or does Tesla just need a quick update to make is compatible with iOS 11?
  2. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Seems to work for my new 8 Plus. Didn’t get a chance to try old 7 Plus but same data (restored iTunes backup...). Not sure that helps but one data point for you!
  3. Motorolabizz
    Motorolabizz Member
    Calvert County, MD
    Also updated on a 7+ and have tried 4 other vehicle manufacturer infotainment systems with the same issue. Can't use the steering wheel controls and the display is inaccurate. I'm inclined to believe that firmware updates to the car systems might be necessary.
    15' Toyota Corolla
    06' BMW 325xi
    16' Nissan Maxima
    15' Buick Encore
  4. Jason S
    Jason S Model S Sig Perf (P85)
    Rocklin, CA
    That's info from Bluetooth. Try reinit the Bluetooth connections.
    I recall having to restart an AirPlay connection to my home stereo soon after the upgrade, but haven't had any problems since then.
  5. GaryREM
    GaryREM Member
    Fairfax, VA
    My iPhone 6 with iOS 11 works fine.
    However, I did a 'Settings, General, Reset, Reset All Settings' for some issues I was having.
    I think @Jason S has the right idea.
  6. ForeverFree
    ForeverFree Member
    Sherman Oaks, CA
    I had to reboot my drivers’ screen.
  7. alpinebum1
    alpinebum1 Member
    Maryland
    Past updates have required to me to delete and re-add the phone under Bluetooth settings in my Mazda 6. I would delete the pairing in both the phone and car, then re-pair the devices.
  8. Motorolabizz
    Motorolabizz Member
    Calvert County, MD
    Also, as an edit, I was tethered via an Anker lightening cable, no Bluetooth connection.
  9. navinsiri
    navinsiri Member
    Central NJ
    Thanks for all the suggestions!
    I deleted my phone from Bluetooth and reconnected it, then rebooted both screens and my phone. And one of those things must’ve fixed it because it works now!
