IOS App - Ideal vs Rated
Discussion in 'Model S: User Interface' started by MikeNewhouse, Jan 12, 2017.
  1. MikeNewhouse
    MikeNewhouse Member
    Kansas City
    Has anyone noticed that on the Home page in the IOS app the range has switch from Rated to Ideal ?
    I am sure it was always Rated until today when I opened it. Am I going crazy?
  2. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    I could definitely be mistaken, and I have no way to check since I use the android app, and my car is with my wife at the moment, but is it possible the app is just showing the same units you have the car set to display?
  3. MikeNewhouse
    MikeNewhouse Member
    Kansas City
    I suppose that is possible - I can't think that my wife would know how to switch that but I will check when I can get my hands on the car tonight.
  4. jaguar36
    jaguar36 Active Member
    NJ
    Mine shows rated, maybe it depends on what you have the car set for.
  5. seevT
    seevT Member
    SoCAL
    saw a similar issue while charging where the miles shown on the app where higher than rated. checked the car setting and i have set it to rated..(but even with ideal, i should not be seeing higher than 220 for S60 (assuming :270 wh/m). This is on android app
    see my post
    Range Shown on the App while Charging greater than Rated range [S60]
  6. aollivierre
    aollivierre Member
    arlington,tx
    My app doesn't show rate or anything? What am I doing wrong? I only see charge % Thanks
  7. Logan5
    Logan5 Member
    Newton, MA
    The original post is referring to the old version of the app. The new version doesn’t show that.
  8. aollivierre
    aollivierre Member
    arlington,tx
    ok, good. thought was going a little crazy....
