TeslaFi or TeslaMate?Would be cool if there was some way to pull the last efficiency data and display like the stats app in the widget. I imagine this is possible via the api?
I'm currently stuck on this:
I have an iPhone 6S so I'm guessing it's related to screen res?
I've added support for displaying the distance and temperature in other units now:
TEMPERATURE_UNIT=C/F
DISTANCE_UNIT=km/imperial
I've done the following, but am stuck right near end. Just a little help pleas
Thanks in advance for your help!
- I need to edit the parameters.js file to add my API URL, but am not sure where in the file to add it (line 955?) or what the syntax should be?
Stach
Well, the method that I used to copy those 3 .js files was obviously bad (not 955+ lines), so I now have 3 good files, but I'm not sure what the format of the apiurl is in the parameters.js file (does it include the http:// or just everything after that)?
Also, do I need to remove the // in front of each line of the parameter.js file (guessing that means a comment)?
After some researches i've forked your code and managed to add credentials in it, it was quite simple afterall without knowledge of Go.
Thanks again for your work
