iPhone 12 Pro Max and charging
Discussion in 'Model Y: Interior & Exterior' started by rijc99, Nov 13, 2020.
  1. rijc99
    rijc99 Member
    So.Cal
    My charging pad doesn’t seem to charge the Pro Max. Can someone else confirm?
  2. Fobia
    Fobia Member
    Orlando, FL
    Yup I have the same issue. I have it on the apple leather case and it never recognized it.
  3. Kendall
    Kendall Member
    SAN RAMON
    I had some trouble initially but if I pushed it down a bit it started working. I have the apple silicon case on it but it’s definitely more fickle than the 11 pro it replaced.
  4. bbmertz
    bbmertz Model Y
    North Carolina
    Yes, it will charge (albeit slowly) without a case, however I cannot get the 12 Pro Max to charge with a case on, since the phone needs to sit lower on the charging pad. I can get it to charge in the case if I slide off the plastic lip on the bottom of the charging pad, but this would allow the phone to fall into the storage compartment below.
  5. rijc99
    rijc99 Member
    So.Cal
    ok. Thanks for checking. I guess I need to stick a apple MagSafe puck on top of the Tesla charging pad. I hope Tesla comes out with a charging pad that fits the new phones.
  6. bbmertz
    bbmertz Model Y
    North Carolina
    I did the same thing using double-sided tape so the puck stays in place. It actually charges the phone much faster than the Tesla wireless charging pad using the same USB-C outlet.
  7. burn1010
    burn1010 Member
    NY
    This may be the reason the MY gets the new center console sooner rather than later.
  8. gunthermic
    gunthermic Member
    Dayton, Ohio
    I just got my iPhone 12 Pro XS-Max, and every time I have placed it in MY (Sept Build), it charges it...
  9. rijc99
    rijc99 Member
    So.Cal
    Do you have a case with your 12ProMax? Maybe with the Apple leather case it added just enough to render the coils out of range.
  10. BreatheEasier
    BreatheEasier Member
    Northern Virginia
    I'm having the same issue...will be trying with 2 different cases today. My vin is 9xxx. I wonder if earlier cars have more of an issue than late.
  11. rijc99
    rijc99 Member
    So.Cal
    My vin is 57,xxx. I don’t think it’s a matter of build date. I think the phone’s additional height just places the coils ever so slightly out of reach. I have a scosche charger in my other car that is doing the same thing. However, if I push it just a little lower on the lower arm that holds the phone it will charge. Just a mm and it made the difference between charging or not. Although I doubt it’s charging well since it’s barely in place.
  12. JohnInSanDiego
    San Diego, CA
  13. gunthermic
    gunthermic Member
    Dayton, Ohio
  14. Mo del Y
    Mo del Y New Member
  15. Kaitou Dark
    Kaitou Dark Member
    New York
  16. gunthermic
    gunthermic Member
    Dayton, Ohio
    Of note. The new Pro Max doesn't sync contact or text messages either. Gotta love how new stuff just doesn't work...
  17. seniorcitizen
    seniorcitizen Member
    Maple Grove
    I also got iPhone pro max 12 with leather MagSafe case and charging does not work. I will try a cup holder mount with a built in charger or a taptes charging pad next.
  18. rijc99
    rijc99 Member
    So.Cal
    Does the Taptes mat replace the factory one or sits on top?
  19. JBauer
    JBauer Member
    Toronto
    I just got MY for a few weeks, and thinking to buy a iphone 12 Pro Max as well, so really appreciate all the insights here! For those tried and didn't get charged, I am just curious what if you place your iphone 12 pro max upside down (still in Portrait position) would it start charging?
  20. rijc99
    rijc99 Member
    So.Cal
    Nope. Didn’t work for me even when upside down. Currently using a Apple leather case.
