iPhone 12 Pro Max and charging
Discussion in 'Model Y: Interior & Exterior' started by rijc99, Nov 13, 2020.
  1. HotIce
    HotIce Member
    MD
    Doesn't MagSafe charge at 15w?
  2. rijc99
    rijc99 Member
    So.Cal
    Only if you use the right wall plug and charging puck.
  3. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    It's right on the product page: "Qi wireless charging up to 7.5W"
    iPhone 12 Pro and 12 Pro Max - Technical Specifications
    No problems here on any Qi charger other than the Y. And even that one appears to be because Tesla slightly undersized the ledge.
    Separate note, I can confirm the modified spacer model I was working on makes the Pro Max in both the Apple leather and silicone cases work in both the driver and passenger side positions with the stock charging pad. Thicker cases should also work, but I don't have any to test.
    I'll post the model later this weekend in case anyone with a 3D printer wants to whip one up.
  4. Gizmotoy
    Bay Area, CA
    Alright, as promised, the updated spacer STL for the 2020 Model Y. Tested with a 12 Pro Max and both the Apple silicone and leather cases over bumps and rough terrain. Looks solid. Offered free for non-commercial use.
    2020 Model Y wireless charging phone spacer by Gizmotoy
    • Like x 5
  5. BreatheEasier
    BreatheEasier Member
    Northern Virginia
    I installed the Jeda spacer and my Pro Max still doesn't charge. I have an Otterbox Symmetry Clear series case, which really isn't that big.
  6. rotiv54436
    rotiv54436 Member
    Fremont, CA
    #126 rotiv54436, Dec 22, 2020
    To my disappointment the iPhone Pro Max does not charge with the factory wireless charger. For this reason i've created a charging "dock bar" that lowered and deeper than the factory to accept the iPhone Pro Max
    The dockbar is deep enough to accept cases that are 12mm or less, so far i've tested the iPhone 12 Pro Max, Otterbox Symmetry and the Ringke Onyx case with no issues. i've uploaded the STL file to Thingiverse for those interested in printing.
    Charging "Dock Bar" for iPhone Pro Max's by csin
  7. 2101Guy
    2101Guy Active Member
    have a link to the etsy version?
  8. drrajanvr
    drrajanvr New Member
    Canada
    Facing the same problem. iPhone 22 pro max, does not charge with the  case- leather one.
  9. tech4cars
    tech4cars Member
    Aptos CA
    Did some further testing which produced erratic results. My wife has the iPhone 12 Pro Max, and I have the iPhone (10) XS Max. My phone support wireless charging on the Qi charger standard. I have only found info on the Apple.com site that indicates the iPhone 12 ProMax supports the Apple Mag Safe wireless charging. There is NO MENTION of compatibility with Qi Wireless charging for the iPhone 12 Pro Max. We found that her phone would charge if placed on the Qi wireless pad on the Model Y console cover ONLY if she removes it from her approved Apple plastic case. My iPhone 10 charges fine on the cover while its aftermarket, non authorized case is on. If we try to charge her iPhone 12 Pro Max on an indoor atomi brand Qi wireless charger, it appears to charge with the authorized Apple case off. If we try to charge with the case ON, then the charger cycles On and Off, and does NOT charger her phone. I note that this charger is rated a 10W charger. I believe the iPhone 12 ProMax has a 30W recommended charger. Thus, while wireless charging may appear to work partially, I do not believe the wireless charging pad in the Model Y is fully compatible with the iPhone 12 Pro Max charging requirements. Perhaps someone on here has further info on the Apple iPhone 12 wireless charging requirements, and can offer further comment?
  10. tech4cars
    tech4cars Member
    Aptos CA
  11. tech4cars
    tech4cars Member
    Aptos CA
    Hmm, yeah see the Qi mention on your link. When I went looking for it on the iPhone tech specs previously, I didn't see it....only the Mag Safe...Even so, the Qi wireless chargers we have do NOT work reliably on my wife's 12 Pro Max.
  12. mrsandman
    mrsandman Member
    Los Angeles
    Will these spacers work on the 3 as well?
  13. Gizmotoy
    Bay Area, CA
    Not sure, that's why I labeled them strictly as Model Y spacers. That said, both of the pieces I'm connecting to say something like "Model 3/Y Dock" along with the part number stamped on the back, so I suspect the Model 3s with the matching interior will also work. rotiv54436's solution would likely work too.
  14. Srad600Volt
    Srad600Volt Member
    Southern California
    Yep, this is definitely part of my issue. It's partly the bottom lip on the charging pad being too tight, but recently my phone wouldn't charge at all (wirelessly). Once I rebooted it, it began charging wirelessly again. Hopefully Apple get's this resolved quickly.
  15. BreatheEasier
    Northern Virginia
    I'm still not able to charge without removing my Otterbox Symmetry case...even with a spacer. I can remove the spacer/resting bar altogether, and it doesn't matter where I place my iPhone 12 Pro Max - the case simply must be just thick enough and blocks the ability to charge. Seems to charge just fine with the case off, with or without the spacer. Rebooting the phone has no impact.
  16. Kobicue
    Kobicue Member
    Houston
    The etsy spacer doesn't work either. It helped my phone, pixel 4xl consistently charge as sometimes it didn't depending on the angle I place it on with the oem trim but still no luck for my finacees iphone 12pro max with a case.
    May have to give gizmotoys spacer a try, if I can find a 3D printer to use.
  17. CapsEngineer
    CapsEngineer Member
    Maryland
    Does it work with the case on on any Qi charger?
  18. BreatheEasier
    Northern Virginia
    Don't know...I don't have one to test with.
  19. Golflaw4
    Golflaw4 Member
    Didn’t work for me. Just a phone holder spot now lol
  20. rotiv54436
    rotiv54436 Member
    Fremont, CA
    i'm charging fine with symmetry case; did you try my dock bar replacement?
