Iphone Tesla app
Discussion in 'Model X: User Interface' started by Gary52, Apr 21, 2018.
  1. Gary52
    Gary52 Member
    Chicago Area
    My iPhone says app says “temporary maintenance. Please try again later”. Has anyone else had this message and how long does it last.
  2. trace
    trace Member
    Michigan
  3. FlyF4
    FlyF4 Son of a MX
    moved to San Diego
    There are already a lot of threads about this. Try search ;)
  4. Gary52
    Gary52 Member
    Chicago Area
    I did search but obviously not the right keyword’s. Thanks for replying
  5. FlyF4
    FlyF4 Son of a MX
    moved to San Diego
    yes, it is not always perfect. Usually the first two words of your error is good enough. I also always scan the "Recent Threads" when something new like this crops up. Usually you see where someone else beat you to it :)
  6. psgabin
    psgabin Member
    livingston, nj
    coincidence hulu is down also?
  7. Gary52
    Gary52 Member
    Chicago Area
    Thanks again for the advice
  8. Daniellane
    Daniellane Active Member
    Camas, Washington
  9. DerekH
    DerekH Member
    Los Angeles CA
    yes, but it looks like that thread is weeks ago, not from today
  10. Daniellane
    Camas, Washington
    Post #26-194 all today
  11. Rhubarb7
    Rhubarb7 Member
    north NJ
    I have an App problem - I'm not sure its a software or hardware fault however, maybe one of design?! I live in the concrete jungle, and the App seldom works. According to the SC that is due to all the Wi-Fi around, and apparently the X tries to connect to whatever it sees. As a result, my App seldom updates - when I open it, it just gives data from last week on a dull screen, and continually "cycles" trying to get my X info - but cannot.
    So I can go to my Wi-Fi settings on the X, turn off Wi-Fi, the little icon top right on the MCU then shows LTE/cellular, and sure enough within seconds, the App makes a connection and updates just fine.
    The problem is that, when you turn off Wi-Fi, there is a little message on the MCU stating that the Wi-Fi will turn back "on the next time you drive." So this appears to mean that I always have to turn off Wi-Fi when I stop the car, in order for the App to work?
    Baffled here, thanks for any insights.
